<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>RAM SS - Check Self Weight of Deck</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/109852/ram-ss---check-self-weight-of-deck</link><description>Is there any easy way to see how RAM SS calculated the self-weight of a composite concrete on metal deck? I want to find out if it uses the full depth of the concrete or takes into account the corrugations of the deck profile. For example, a 5&amp;quot; slab would</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: RAM SS - Check Self Weight of Deck</title><link>https://communities.bentley.com/thread/334539?ContentTypeID=1</link><pubDate>Fri, 14 Aug 2015 18:24:44 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:b4ae201b-3ba3-472d-9899-f8751ae7d2a5</guid><dc:creator>Seth Guthrie</dc:creator><description>&lt;p&gt;Take a look at RAM Manager manual, section&amp;nbsp;7.2 Metal Deck Table File Format. There is a property called AcRib which is &amp;quot;the area of concrete in the rib per foot or per meter of deck width (in.2/ft. or cm2/m).&amp;quot;&lt;/p&gt;
&lt;p&gt;This value is used for the calculation of the self-weight of the concrete in the deck ribs.&lt;/p&gt;
&lt;p&gt;The AcRib plus the Ac for the topping times the concrete density + the metal deck self-weight determines the total unit self-weight area load for the deck.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Using normal or light-weight concrete is one significant factor, the topping thickness and metal deck self weight properties are others.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
