I'm curious what the most efficient method might be for quickly reviewing steel beam deflections for members designated at lateral beams in RAM SS? In the RAM Steel Beam module it is fairly easy to see beam deflections either case by case or by report but I'm not sure how one approaches this with frame beams.Thanks in advance!
You can display vertical deflections at quarter points along the beam span in RAM Frame. To do this, click on Process - Results - Deflected Shape and use the options marked in the screen capture below. The option is available in both Load Cases and Load Combinations mode in RAM Frame
Answer Verified By: Stephanie Spann
