INSTABILITY WARNING IN MX DIRECTION IN 3D MODELING
Dear All,
I have analyze the model in 3d staad. it is giving me following warning
***WARNING -  INSTABILITY AT JOINT   114   DIRECTION = MX
  PROBABLE CAUSE SINGULAR-ADDING WEAK SPRING
  K-MATRIX DIAG=  1.0838102E+04 L-MATRIX DIAG= -3.0140654E-09 EQN NO     790
  ***NOTE - VERY WEAK SPRING ADDED FOR STABILITY
    **NOTE** STAAD DETECTS INSTABILITIES AS EXCESSIVE LOSS OF SIGNIFICANT DIGITS
             DURING DECOMPOSITION. WHEN A DECOMPOSED DIAGONAL IS LESS THAN THE
             BUILT-IN REDUCTION FACTOR TIMES THE ORIGINAL STIFFNESS MATRIX DIAGONAL,
             STAAD PRINTS A SINGULARITY NOTICE. THE BUILT-IN REDUCTION FACTOR
             IS   1.000E-09
             THE ABOVE CONDITIONS COULD ALSO BE CAUSED BY VERY STIFF OR VERY WEAK
             ELEMENTS AS WELL AS TRUE SINGULARITIES.
I have tried all the options which is mentioned in all previous posts. kindly help me to resolve all warnings. I have attaching the staad file for more information. JS-0103-3D-LSM--FINAL.std
