I am working with a fairly large model consisting of a steel frame building with the floor modeled using plates connected to the beams. I keep getting the following error:
***ERROR - AT JOINT 2234 DIRECTION = MZ
PROBABLE CAUSE NEGATIVE DIAGONAL =>LDLT MTX
K-MATRIX DIAG= 1.1249905E+06 L-MATRIX DIAG= -1.1469693E-02 EQN NO 2895
Does anyone have any advice on how to fix this or what the cause of the error is?
Thanks.
Answer Verified By: Jennifer
