In the RAM Steel Beam/Joist Module, what happens with camber once you manually update a beam's design using the View/Update command? Is there no way to include camber when doing it this way?
I like to get my stress ratios under 0.90 in early designs but I noticed that none of these beams include camber once I update their design manually.
Thanks!
