Is STAAD Pro 2007 support the design of Taperred Steel Pole ?
BR
Can you please check below code, I am trying to use the AISC 360-16 to check the tapered tubular (12 sided Columns, and Beams), however I am still getting the waning messages that "WARNING: DESIGN OF SECTION FOR MEMBER # 1 IS NOT SUPPORTED."
STAAD SPACE TUBULAR MODEL DESTART JOB INFORMATIONENGINEER DATE 06-Apr-21JOB CLIENT OKLAHOMA UNIVERSITYJOB NO CEES 5970ENGINEER NAME MUSTAFA ALI NEHAIDEND JOB INFORMATION************************************************ STAAD.Pro Generated Comment ************************************************* 3 0 20 0 6 30 20 0***********************************************OUTPUT WIDTH 72UNIT FEET KIPJOINT COORDINATES1 0 0 0; 2 36 0 0; 3 0 36 0; 4 8 36 0; 5 18 36 0; 6 36 36 0; 7 0 43 0;8 36 43 0; 9 8 43 0; 10 28 43 0; 11 18 43 0; 17 0 53 0; 18 36 53 0;19 0 63 0; 20 36 63 0; 21 72 53 0; 22 72 0 0; 23 72 63 0; 24 72 36 0;25 72 43 0; 26 28 36 0; 27 64 36 0; 28 54 36 0; 29 64 43 0; 30 44 43 0;31 54 43 0; 32 44 36 0;MEMBER INCIDENCES1 1 3; 2 3 7; 3 2 6; 5 3 4; 6 4 5; 7 5 26; 20 7 9; 21 9 11; 22 10 11;23 8 10; 24 7 17; 25 17 19; 27 18 20; 28 6 8; 29 8 18; 30 8 30; 31 6 32;32 22 24; 33 24 25; 34 25 21; 35 21 23; 36 26 6; 37 27 24; 38 28 27;39 29 25; 40 30 31; 41 31 29; 42 32 28;MEMBER PROPERTY5 TO 7 20 TO 23 30 31 36 TO 42 PRIS DOD STA 1 END 1 THI 0.021 3 32 PRIS DOD STA 2.75 END 1.815 THI 0.022 28 33 PRIS DOD STA 1.815 END 1.702 THI 0.0224 29 34 PRIS DOD STA 1.702 END 1.34 THI 0.02MEMBER PROPERTY AMERICAN25 27 35 TABLE ST PIPS20*MEMB TRUSS*14 TO 23UNIT INCHES KIPDEFINE MATERIAL STARTISOTROPIC STEELE 29000POISSON 0.3DENSITY 0.000283ALPHA 6e-06DAMP 0.03TYPE STEELSTRENGTH FY 36 FU 58 RY 1.5 RT 1.2ISOTROPIC STEEL_65KSIE 29000POISSON 0.3DENSITY 0.000283ALPHA 6.5e-06DAMP 0.03G 11153.8TYPE STEELSTRENGTH FY 65 FU 80 RY 1 RT 1END DEFINE MATERIALUNIT FEET KIPCONSTANTSMATERIAL STEEL MEMB 25 27 35MATERIAL STEEL_65KSI MEMB 1 TO 3 5 TO 7 20 TO 24 28 TO 34 36 TO 42SUPPORTS1 2 22 FIXEDLOAD 1 DEAD AND LIVE LOADSELFWEIGHT Y -1.15 LOAD 2 WIND FROM LEFTLOAD 3 LOADTYPE None TITLE LOAD CASE 4 WIRE TENSIONJOINT LOAD9 TO 11 29 TO 31 FX 0.287 FY -1.434 FZ 417 18 21 FX 0.2 FY -1 FZ 34 5 9 TO 11 26 TO 32 FX 0.2 FY -1LOAD COMB 4 COMBINATION LOAD CASE 41 1.0 2 1.0 3 1.0 PERFORM ANALYSIS*CODE ASCE 1997*CODE LRFDPARAMETER 1CODE AISC UNIFIED 2016CHECK CODE ALL*CODE ASCE 1997PARAMETER 2CODE LRFDSTEEL MEMBER TAKE OFF ALL*CODE ASCE 1997PARAMETER 3CODE LRFDSTEEL TAKE OFF ALLFINISH
