RAM Structural System Steel Beam Crash
I am having a problem running a certain model in RAM Structural System v14.07. The building is composite steel framing with steel columns, concrete shear walls, and the lowest level is a concrete two way slab.
I have the building fully modeled, but when I try to design the steel beams, the module crashes. I've run many other models before and never had this problem occur. The steel column design module crashed while I was running v14.06, but works now after I updated to v14.07. Any suggestions on what could be causing this?
Parents Reply Children
