updated list of references.
could you please list out all the references after ref 60. which are reported in limcon output.
Also please note that ref 15 and ref 16 code title have been interchangebily used.
Prequalified Connections  for Special and Intermediate Steel Moment Frames for  Seismic Applications should be ANSI.AISC 358-05 , not ANSI/AISC 341-05
Seismic Provisions for Structural Steel Buildings should be ANSI/AISC 341-05   not  ANSI.AISC 358-05 .
Parents Reply Children
  • seth ,
    good to hear that it is listed in V 3.63.2.4 , but since those where incorporated in earlier version itself , i would request you to please atleast list the other reference in this forum .
    for the people who are using a little older version ,sometimes it become difficult when the refernce is reported as REF 61 but we donot know what the reference is.
    please do it , my humble request.
    Best Regards,
    Alex Immanuel Thainese
  • 1. ANSI/AISC 360-05 - Specification for Structural
    Steel Buildings
    - American Institute of Steel Construction - 2005.
    ANSI/AISC 360-10 - Specification for Structural
    Steel Buildings
    - American Institute of Steel Construction - 2010.
    2. CAN/CSA-S16-01 - 2003 - Limit States Design of
    Steel Structures.
    CAN/CSA-S16-09 - 2009 - Limit States Design of
    Steel Structures.
    3. BS 5950-1:2000 Structural Use of Steelwork in
    Building - Part 1: Code of Practice for Design of
    Rolled and Welded Sections.
    4. AS 4100 - 1998 - Steel Structures.
    5. NZS 3404:Part 1:1997 - Steel Structures Standard.
    6. Steel Construction Manual - 13th Edition (SCM13)
    Steel Construction Manual - 14th Edition (SCM14)
    - American Institute of Steel Construction - 2011.
    7. Hollow Structural Sections Connections Manual
    - American Institute of Steel Construction - 1997.
    8. Handbook of Steel Construction
    - 8th Edition
    - Canadian Institute of Steel Construction - 2004.
    9. Joints in Steel Construction
    - Moment Connections - Publication P207
    - SCI & BCSA - 1995.
    10. Joints in Steel Construction
    - Simple Connections - Publication P212
    - SCI & BCSA - 2002.
    11. Design of Structural Connections - 4th Edition
    - T.J. Hogan & I.R. Thomas
    - Australian Steel Institute - 1994.
    12. Design of Structural Steel Hollow Section
    Connections - 1st Edition
    - A.A. Syam & B.G. Chapman
    - Australian Steel Institute - 1996.
    13. Recommended Seismic Design Criteria for New
    Steel Moment-Frame Buildings - FEMA-350
    - Chapter 3: Connection Qualification
    - Federal Emergency Management Agency - 2000.
    14. Commentary and Recommendations on FEMA-350
    - SEAOC - January 2002.
    15. ANSI/AISC 358-05 - Seismic Provisions for
    16. ANSI/AISC 341-05 - Prequalified Connections for
    17. Seismic Design Manual
    - American Institute of Steel Construction - 2007.
    18. Flush and Extended Multiple Row Moment End Plate
    Connections - T.M. Murray & W.L. Shoemaker
    - Steel Design Guide 16
    - American Institute of Steel Construction - 2002.
    19. Extended End Plate Moment Connections
    - Seismic and Wind Applications
    - 2nd Edition - T.M. Murray & E.A. Sumner
    - Steel Design Guide 4
    - American Institute of Steel Construction - 2004.
    20. Stiffening of Wide Flange Columns at Moment
    Connections: Wind and Seismic Applications
    - C.J. Carter
    - Steel Design Guide 13
    - American Institute of Steel Construction - 1999.
    21. High Strength Bolts - A Primer for Structural
    Engineers - G.L. Kulak
    - Steel Design Guide 17
    22. Base Plate and Anchor Rod Design
    - 2nd Edition - J.M. Fisher & L.A. Kloiber
    23. Handbook of Structural Steel Connection Design
    and Details - A.R. Tamboli - McGraw-Hill - 1999.
    24. Limit States Design in Structural Steel - 7th Edition
    - G.L. Kulak & G.Y. Grondin
    - Canadian Institute of Steel Construction - 2002.
    25. Hollow Structural Section Connections and Trusses
    - A Design Guide
    - J.A. Packer & J.E. Henderson
    - Canadian Institute of Steel Construction - 1997.
    26. Steel Designers' Manual - 6th Edition
    - The Steel Construction Institute - 2003.
    27. Design Model for Bolted Moment End Plate
    Connections Using Rectangular Hollow Sections
    - A.T. Wheeler, M.J. Clarke, G.J. Hancock,
    T.M. Murray
    - University of Sydney Research Report R745 - 1997.
    28. Design Model for Bolted Moment End Plate
    Connections Joining Rectangular Hollow Sections
    Using Eight Bolts
    - University of Sydney Research Report R827 - 2003.
    29. Seismic Behavior and Design of Gusset Plates
    - Abolhassan Astaneh-Asl
    - Structural Steel Educational Council - 1998.
    30. Design of Pinned Column Base Plates
    - G. Ranzi & P. Kneen
    - ASI - Steel Construction Vol. 36 No. 2 - Sep. 2002.
    31. Gusset Plate Connection to Round HSS Tension
    Members
    - J.J. Roger Cheng & G.L. Kulak
    - AISC Engineering Journal 4th Quarter - 2000.
    32. The Design of Pins - R.Q. Bridge
    - Proceedings of the 16th Australasian Conference on
    the Mechanics of Structures and Materials - 1999.
    33. Design of Portal Frame Buildings - 3rd Edition
    - S.T. Woolcock, S. Kitipornchai, M.A. Bradford
    - Australian Steel Institute - 1999.
    34. Handbook 1
    - Design of Structural Steel Connections
    - T.J. Hogan & S.A. Munter
    - Australian Steel Institute - 2007.
    35. Design Guide 1
    - Bolting in Structural Steel Connections
    36. Design Guide 2
    - Welding in Structural Steel Connections
    37. Design Guide 3 - Web Side Plate Connections
    38. Design Guide 4 - Flexible End Plate Connections
    39. Design Guide 5 - Angle Cleat Connections
    40. Design Guide 6 - Seated Connections
    41. Design Guide 10
    - Bolted Moment End Plate Beam Splice Connections
    - T.J. Hogan & N. van der Kreek
    - Australian Steel Institute - 2009.
    42. Design Guide 11
    - Welded Beam to Column Moment Connections
    43. Design Guide 12
    - Bolted End Plate to Column Moment Connections
    44. Design Guide 13 - Splice Connections
    45. BS EN 1993-1-1:2005
    - Eurocode 3: Design of Steel Structures
    - Part 1-1: General Rules and Rules for Buildings.
    46. BS EN 1993-1-5:2006
    - Part 1-5: Plated Structural Elements.
    47. BS EN 1993-1-8:2005
    - Part 1-8: Design of Joints.
    48. The Behaviour and Design of Steel Structures to
    EC3 - 4th Edition - N.S. Trahair, M,A. Bradford,
    D.A. Nethercot, L. Gardner - Taylor & Francis - 2008.
    49. Structural Design of Steelwork to EN 1993 and
    EN 1994 - 4th Edition
    - Lawrence Martin & John Purkiss
    - Butterworth-Heinemann - 2008.
    50. Designing Compact Gussets with the Uniform Force
    Method - L.S. Muir
    - AISC Engineering Journal 1st Quarter - 2008.
    51. Effective Length Factors for Gusset Plate Buckling
    - Bo Dowswell
    - AISC Engineering Journal 2nd Quarter - 2006.
    52. Hollow Structural Section Connections
    - J.A. Packer, D.R Sherman, M. Lecce
    - Steel Design Guide 24
    53. Design Guide (1) for Circular Hollow Section Joints
    Under Predominantly Static Loading
    - J. Wardenier, Y. Kurobane, J.A. Packer,
    G.J. van der Vegte, X.L. Zhao
    - CIDECT - 2008.
    54. Design Guide (3) for Rectangular Hollow Section
    Joints Under Predominantly Static Loading
    - J.A. Packer, J. Wardenier, X.L. Zhao,
    G.J. van der Vegte, Y. Kurobane
    - CIDECT - 2009.
    55. Steel Structures Design and Behavior
    - 5th Edition - C.G. Salmon, J.E. Johnson, F.A. Malhas
    - Pearson Prentice Hall - 2009.
    56. Design Guide 7
    - Pinned Base Plate Connections for Columns
    - T.J. Hogan - Australian Steel Institute - 2011.
    57. NCCI: Shear resistance of a fin plate connection
    - SN017a-EN-EU - 2005.
    58. NCCI: Shear resistance of a simple end plate
    connection - SN014a-EN-EU - 2005.
    59. CIDECT Report 8G-10/06
    - Slotted Connections to Hollow Sections
    - G. Martinez-Saucedo & J.A. Packer - 2006.
    60. ECCS TC 10
    - European Recommendations for the Design of
    Simple Joints in Steel Structures - 2009.
    61. Steel Construction Vol. 43 No. 2
    - Design Model for Light Bracing Cleat Connections
    - T.J. Hogan & R.T. Collins
    - Australian Steel Institute - 2010.
    62. Tubular Design Guide 20 (TDG20)
    - Background and Design Basis
    - P.W. Key & A.A. Syam
    - Australian Steel Institute - 2013.
    63. Tubular Design Guide 21 (TDG21)
    - Bolted Bracing End Connections
    64. Tubular Design Guide 22 (TDG22)
    - Bolted Bracing Cleats
    65. Tubular Design Guide 23 (TDG23)
    - Plate Fitments
    66. Tubular Design Guide 24 (TDG24)
    - Bolted Planar Connections
    67. Tubular Design Guide 25 (TDG25)
    - Fully Welded Simple Planar Connections
    68. Tubular Design Guide 26 (TDG26)
    - Fully Welded Gap Planar Connections
    69. Tubular Design Guide 27 (TDG27)
    - Fully Welded Overlap Planar Connections
    - Australian Steel Institute - 2014.
    70. Gusset Plates in Steel Bridges
    - Design and Evaluation
    - Structural Steel Educational Council - 2010.
