I try to run the analysis and CODE CHECK with a LOAD LIST using AISC 360-10 on a pretty big STAAD model and I receive the error message "Exception[access violation]Raised! Aborting Analysis....."
I have read other post on this forum relating that problem on which it says that it should be fixed with the release 20.07.10.65. However, I use release 20.07.10.66 and SS? and I still got that problem. If I reduce the number of load cases in the LOAD LIST command, STAAD complete the analysis. I would like to know how I can run the analysis and CODE CHECK for all the load cases specified. You will find my STAAD.Pro model attached.
Thanks in advance,
Julien Richard, Eng, M.A.Sc.HATCH
Building model.std
try to run the same model in connect version 22.03.00.28. this error is again seen in version 22.07.00.160.
The model runs fine in STAAD.Pro CE 22.08.00.175, so if you are not using this version yet, you may need to upgrade and check again.
after upgrading to STAAD.Pro CE 22.08.00.175, the new error is,
*** ERROR: TOTAL NUMBER OF LOAD CASES EXCEEDED THE RELATIVE CAPACITY ASSIGNED FOR PROCESSING PLATE RESULTS. USE "SET NL" TO INCREASE THE MEMORY CAPACITY. IF ALREADY DEFINED THEN CONSIDER INCREASING "SET NL" TO AT LEAST # 693 !
so what is set NL command and why do we use it? when should we use that?
Please refer below link.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/39292/what-is-the-set-nl-command
Refer the last line which is important in this case.
