I'm getting a "Huge Displacements" warning on a simple RAM elements model. All all accounts, the model appears stable and the maximum nodal displacements are very very small, less than .1". Any suggestions on what might be causing this warning?
I am encountering the same issue. I checked the rotation at each node and they are a max of 5", which I am unable to track the node. (It does not display the node number). I am not sure what is causing the warning to pop-up! Any advise regarding this? Thanks in advance!
