Rcdc borrows analysis result from staad for design. Ok. But Rcdc has the option to change the sectional properties of columns and beams. The design forces in members in staad are dependent not only on loads but also on sectional properties. Under the circumstances how Rcdc can change the section on its own without reanalysing in staad. Please comment.
Answer Verified By: sureshprsharma
you didnt answer how? How do you change failing members size in RCDC?!?!?
After design if the member fails, you have the option Resign Section and Redesign Column/Beam option in RCDC which will allow you to change the size of the member
hi,
i have an issue that i have model L beam(b=500,depth=320,slab thickness=150) in user table in staad (beam no:25 in my model)and
while designing in RCDC i seen that beam orientation have changed to b=320,depth=500mm in input and design table why and how can i slove this issue?
i have attached model for your reference.../5810.std
