When checking the output Staad shows the following:
(FOR BEAMS, COLUMNS AND PLATES DESIGNED ABOVE)
NOTE: CONCRETE QUANTITY REPRESENTS VOLUME OF CONCRETE IN BEAMS, COLUMNS, AND PLATES DESIGNED ABOVE. REINFORCING STEEL QUANTITY REPRESENTS REINFORCING STEEL IN BEAMS AND COLUMNS DESIGNED ABOVE. REINFORCING STEEL IN PLATES IS NOT INCLUDED IN THE REPORTED QUANTITY. TOTAL VOLUME OF CONCRETE = 206.8 CU.METER BAR SIZE WEIGHT NUMBER (in lbs) -------- -------- 10 2829 12 83 16 6993 20 4799 25 16347 32 7578 40 9115 ------------ *** TOTAL= 47744
In this quantity, Staad is considering the stirrups?
Sudip Narayan Choudhury
Answer Verified By: Rajat
