When am applying the wind load,some portions are not getting affected by wind.It is the place wherever i did offset to columns...For getting the perfect structural model,i have to offset the columns.But wherever i did the offsets,there no wind loads are applied..All ranges are perfect...X,Y,Z...I have pefectly did.But this is the problem..Please Help..Here am attaching my stad file with it...I didnt give the full loads..I just gave the wind load in x direction..please help...
ARTECH.std
Hi, Neeraj
The expose area should be a closed plane. But there is no a plane for hightlight region in your model .
I suggest you add some virtual column to generate a plane.
