Hi to all,
Please find attached STAAD input file below.
I am a bit confused with the design ratio (strength) of angle bar members which has offset property. My structure is a mechanical car lift with angle bars and channels as frame and steel plate as the platform. I applied offsets and beta angle property to account for the effect of actual positioning of each members but somehow found some hard time to understand the design consideration used by STAAD. The two small piece of angle bar (350mm) is acting inconsistently, using section of 75x75x6.0mm angle bar, i get max design ratio of 1.126, but if i used a section of 50x50x5.0mm all members passed the analysis and safe. I have gone all thru the previous discussions regarding member offsets and i just want to know the real story behind this offset function of STAAD. Is this applicable for offsetting members perpendicular to its cross section? How does STAAD recalculates the stiffness of the structure based on the offset value of the members?
Any advice and clarifications will be highly appreciated! Thank you in advance!
Master Mac
STAAD INPUT FILE:
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 28-Oct-15END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 5 0 0; 3 0 0 2.3; 4 5 0 2.3; 5 1.3 0 0; 6 1.3 0 2.3; 7 2.5 0 0;8 2.5 0 2.3; 9 3.7 0 0; 10 3.7 0 2.3; 11 0 0 1.95; 12 5 0 1.95; 13 1.3 0 1.95;14 2.5 0 1.95; 15 3.7 0 1.95; 16 0 0 0.35; 17 5 0 0.35; 18 1.3 0 0.35;19 2.5 0 0.35; 20 3.7 0 0.35; 22 0.315 0 2.3; 24 4.685 0 2.3; 25 0.315 0 0;26 4.685 0 0; 27 0 0 1.51; 28 5 0 1.51; 29 0 0 0.79; 30 5 0 0.79;31 1.3 0 0.79; 32 3.7 0 0.79; 33 1.3 0 1.51; 34 3.7 0 1.51; 35 0.315 0 0.79;36 0.315 0 1.51; 37 4.685 0 0.79; 38 4.685 0 1.51; 39 0.52 0 2.3;40 0.75 0 2.3; 41 4.25 0 2.3; 42 4.48 0 2.3; 43 4.25 0 1.95; 44 4.48 0 1.95;45 0.52 0 1.95; 46 0.75 0 1.95;MEMBER INCIDENCES2 3 22; 3 1 16; 4 2 17; 6 6 8; 7 5 18; 9 8 10; 10 7 19; 12 10 41; 13 9 20;14 11 3; 15 12 4; 16 13 6; 17 14 8; 18 15 10; 19 16 29; 20 17 30; 21 18 31;22 19 14; 23 20 32; 24 16 18; 25 11 45; 31 22 39; 33 24 4; 34 13 14; 35 14 15;36 15 43; 37 18 19; 38 19 20; 39 20 17; 40 2 26; 41 5 25; 42 7 5; 43 9 7;44 25 1; 45 26 9; 47 18 14; 48 19 15; 62 27 11; 63 28 12; 64 29 27; 65 30 28;66 31 33; 67 32 34; 68 33 13; 69 34 15; 70 29 35; 71 32 37; 72 27 36; 73 34 38;80 35 31; 81 36 33; 82 37 30; 83 38 28; 84 16 13; 85 20 12; 86 39 40; 87 40 6;88 41 42; 89 42 24; 90 43 44; 91 44 12; 92 45 46; 93 46 13; 94 45 39; 95 46 40;96 43 41; 97 44 42;ELEMENT INCIDENCES SHELL50 16 1 5 18; 51 18 5 7 19; 52 19 7 9 20; 53 20 9 2 17; 54 3 11 13 6;55 6 13 14 8; 56 8 14 15 10; 57 10 15 12 4; 59 13 18 19 14; 60 14 19 20 15;74 16 18 31 29; 75 27 29 31 33; 76 11 27 33 13; 77 32 20 17 30; 78 34 32 30 28;79 15 34 28 12;START GROUP DEFINITIONMEMBER_CH200X75X3.0MM 2 6 9 12 31 33 40 TO 45 86 TO 89_EA75X75X6.0MM 3 4 7 10 13 TO 25 34 TO 39 62 TO 73 80 TO 83 90 TO 97_EA50X50X5.0MM 47 48 84 85_FRAMING 2 TO 4 6 7 9 10 12 TO 25 31 33 TO 45 47 48 62 TO 73 80 TO 97ELEMENT_PLATE_4.0MM 50 TO 57 59 60 74 TO 79END GROUP DEFINITIONSTART USER TABLETABLE 1UNIT METER KNANGLE75X75X5MM0.075 0.075 0.005 0.0148867 0.00025 0.00025TABLE 2UNIT METER KNCHANNELLIP_C_200X75X20X3.0MM0.001032 0.2 0.003 0.075 0.003 6.1917e-006 5.40272e-007 3.096e-009 -0.0171977 0.0006 0.0003TABLE 3UNIT METER KNANGLE130X130X8MM0.13 0.13 0.008 0.0258489 0.000693333 0.000693333TABLE 4UNIT METER KNANGLE75X75X6.0MM0.075 0.075 0.006 0.0148239 0.0003 0.0003ENDELEMENT PROPERTY50 TO 57 59 60 74 TO 79 THICKNESS 0.004DEFINE MATERIAL STARTISOTROPIC STEELE 2.05e+008POISSON 0.3DENSITY 76.8195ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY BRITISH2 6 9 12 31 33 40 TO 45 86 TO 89 UPTABLE 2 LIP_C_200X75X20X3.0MMMEMBER PROPERTY BRITISH47 48 84 85 TABLE ST UA50X50X5MEMBER PROPERTY BRITISH3 4 7 10 13 TO 25 34 TO 39 62 TO 73 80 TO 83 90 TO 97 UPTABLE 4 75X75X6.0MMCONSTANTSBETA 135 MEMB 94 96BETA 225 MEMB 95 97BETA 45 MEMB 3 7 10 14 16 17 19 21 22 25 34 TO 36 47 62 64 66 68 72 73 81 -83 84 90 TO 93BETA 315 MEMB 4 13 15 18 20 23 24 37 TO 39 48 63 65 67 69 TO 71 80 82 85MATERIAL STEEL ALLSUPPORTS22 24 TO 26 35 TO 38 PINNEDMEMBER OFFSET3 4 7 10 13 TO 25 34 TO 39 47 48 62 TO 69 84 85 90 TO 93 START 0 -0.0454 03 4 7 10 13 TO 25 34 TO 39 47 48 62 TO 69 84 85 90 TO 93 END 0 -0.0454 070 TO 73 80 TO 83 START 0 -0.1204 070 TO 73 80 TO 83 END 0 -0.1204 094 TO 97 START 0 -0.0796 094 TO 97 END 0 -0.0796 0LOAD 1 LOADTYPE Dead TITLE SELFWEIGHTSELFWEIGHT Y -1 LIST 2 TO 4 6 7 9 10 12 TO 25 31 33 TO 45 47 48 50 TO 57 59 -60 62 TO 85LOAD 2 LOADTYPE Live TITLE WHEEL LOAD, UNFACTOREDMEMBER LOAD24 CON GY -4.91 193 CON GY -4.91 0.2536 39 CON GY -4.91 0.3LOAD COMB 3 1.35DL + 1.5P1 1.35 2 1.5 LOAD COMB 4 1.0DL + 1.0P1 1.0 2 1.0 PERFORM ANALYSISLOAD LIST 3PARAMETER 1CODE EN 1993-1-1:2005RATIO 1 mem _FRAMINGSGR 1 mem _FRAMINGTORSION 0 mem _FRAMINGTRACK 2 mem _FRAMINGCHECK CODE mem _FRAMINGFINISH
Sudip Narayan Choudhury
Answer Verified By: Master Mac
