Hi i am using the import / export to text file component of LIMCON to do multiple similar connections at a time and i have noticed that there are features or attributes of the connection that are not read when doing this, ie most check boxes dont update via the text file, eg the gap parameter for between beam/column splice, check box for different bolts on flange and web of splice connection, check box for inner plates on splices, plate grade for BMEP Type D connection, sp1/sp3 for the BMEP Type A and pfi not updated using the text file.
Thanks for prompt reply. Does that mean no option to reliably import many similar connections into Limcon?
Plan is to be able to change one data field for all connections in a large set of standard connections. And then output capacities to achieve a capacity table for the standard connections. Adjustments to be made to give best balance of fabrication norms, constructability and Engineering capacity.
Any thoughts would be appreciated.
