composite beams design using IS800:2007
we are using latest version 20.07.11.45 Build of SS6.
using Deck generation method for composite Slabs.
using code IS800 :2007 LSD & WSD , design of composite beam is showing    ' WARNING: DESIGN OF SECTION FOR MEMBER #      7 IS NOT SUPPORTED.'
Using I800 : 1984 WSD the Program is design the beams.
Kindly Guide How to design the Composite beams using IS800: 2007 LSD & WSD.
floor-is.std
