How to convert Vertical DL to Lateral Loads (x & z directions) with a factor
HI,
How to convert Vertical DL to Lateral Loads (x & z directions) with a factor.  In my shipping/transportation load condition, I need to combine: Equipment dead weight with 0.3 lateral loads of dead weight in 2 directions x & z.
THANK YOU
For example,
**Shipping/Transportation Load Condition:
LOAD 2:
**Original DL:
JOINT LOAD
612 FY -750
613 FY -825
614 FY -1250
MEMBER LOAD
888 CON GY -1250
890 CON GY -400
887 CON GY -600 4
**0.3 Lateral Load in X-Dir
JOINT LOAD
612 FX 225
613 FX 247.5
614 FX 375
MEMBER LOAD
888 CON GX 375
890 CON GX 120
887 CON GX 180 4
**0.3 Lateral Load in Z-Dir
JOINT LOAD
612 FZ 225
613 FZ 247.5
614 FZ 375
MEMBER LOAD
888 CON GZ 375
890 CON GZ 120
887 CON GZ 180 4
  • Hello,
    I used notional load, this opcion take only the vertical load and change its direcction
    I don`t know if it´s the best way but I used it for seismic loads
  • Yes using Notional loads is a good option for what you are trying to achieve.
  • Hi,
    You can use Notional Load which you can derive into vertical load from lateral load.
    Please find the attachment.
    Answer Verified By: Staad123
  • Thank you. You are RIGHT. Use Notional Load to convert vertical load to Lateral Load with any factor
