I just started using Steel design parameters...
Pls. help me out to give proper Lx, Ly & Lz values for the beams in model attached.
Some more queries :
1) Whether all Lx,Ly & Lz are required to define in model ?
2) Whether for columns Lx,Ly & Lz to be defined.
3) My live load a live load of 7KN/m2 on fifth floor . How to apply it on the beams?
Model details
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 12-Aug-14END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 0 0 3.5; 3 3.5 0 0; 4 3.5 0 3.5; 5 0 4 0; 6 0 4 3.5; 7 3.5 4 0;8 3.5 4 3.5; 9 0 8 0; 10 0 8 3.5; 11 3.5 8 0; 12 3.5 8 3.5; 13 0 12 0;14 0 12 3.5; 15 3.5 12 0; 16 3.5 12 3.5; 17 0 16 0; 18 0 16 3.5; 19 3.5 16 0;20 3.5 16 3.5; 21 1.75 16 3.5; 22 0 16 1.75; 23 1.75 16 0; 24 3.5 16 1.75;MEMBER INCIDENCES1 1 5; 2 5 6; 3 6 2; 4 5 7; 5 7 8; 6 8 6; 7 8 4; 8 7 3; 9 9 10; 10 9 11;11 11 12; 12 12 10; 13 13 14; 14 13 15; 15 15 16; 16 16 14; 17 9 5; 18 10 6;19 12 8; 20 11 7; 21 13 9; 22 14 10; 23 15 11; 24 16 12; 25 17 22; 26 17 23;27 19 24; 28 20 21; 29 17 13; 30 18 14; 31 20 16; 32 19 15; 33 21 18; 34 22 18;35 23 19; 36 24 20;START USER TABLETABLE 1 FINALCOL.UPTTABLE 2 ISMB300FIN.UPTTABLE 3 BEAM600.UPTENDDEFINE MATERIAL STARTISOTROPIC STEELE 2.05e+008POISSON 0.3DENSITY 76.8195ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY INDIAN2 4 TO 6 9 TO 16 25 TO 28 33 TO 36 TABLE ST ISMB3001 3 7 8 17 TO 24 29 TO 32 TABLE ST ISMB600CONSTANTSMATERIAL STEEL ALLSUPPORTS1 TO 4 FIXEDLOAD 1 DEAD + LIVEJOINT LOAD21 TO 24 FY -10SELFWEIGHT Y -1 PERFORM ANALYSISPERFORM ANALYSIS PRINT STATICS CHECKPARAMETER 1CODE IS800 LSDCMX 0.9 MEMB 1 3 7 8 17 TO 24 29 TO 32CMZ 0.9 MEMB 1 3 7 8 17 TO 24 29 TO 32CMY 0.9 MEMB 1 3 7 8 17 TO 24 29 TO 32FU 420000 ALLFYLD 250000 ALLKX 1 MEMB 1 3 7 8 17 TO 24 29 TO 32KY 1 MEMB 1 3 7 8 17 TO 24 29 TO 32KZ 1 MEMB 1 3 7 8 17 TO 24 29 TO 32FINISH
Pls. help me out to understand the concept on design parameters(Lx,Ly,Lz)
Please upload the upt file you have used in this model.Thank you.
RAJAT
Please go through the Technical Reference Manual to find out the design parameters
