RAM Steel Beam module not using studs
I am using the RAM Steel Beam module and it won't design a few beams using studs. The initial "design all" designed these beams with errors saying that there were "Not enough studs for 25% composite action (0%)." I tried to manally input the studs using the "View/Update Beam" command but it returns the same error and shows that zero studs were used in the analysis by changing my input back to zero. The beams are long enough for studs to be used; it just seems like the program refuses to use studs in the design.
Thanks for the help!
Parents Reply Children
