PV Solar panel wind analysis in STAAD
Hello friends!
1) Slar panel module of dimension 1.9m x .9 m is mounted over the the 12 m building . I need to support 5 panel each 24 kg using 3 vetical support using 3inch hollow pipe 40mm thickness.This vertical member stands on RCC block with base J bolt is used which has to be designed.
2)Panels angle of tilting is 13'. All 5 panels rests on bracing angle of 50x50x5mm which runs in the centre . This Angle is supported with 40x40x4mm channel parallel to each solar panel.
Parents Reply Children
