Dear Engineers,
Im analysing a steel structure where I have to apply thermal load. below are the datas.
In STAAD we have below 3 things in the input cell. How to calculate this from the above input.
Temperature Change for Axial Elongation
Temperature Differential from Top to Bottom
Temperature Differential from side to side
You can also refer the following post where the same is discussed:-
http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/t/86174
Thank you.
RAJAT
-Vivek
Since the stress is caused on the structure by a change in temperature, knowing the maximum and minimum temperatures alone is not enough. You need to know the average temperature at which the structure was built, which is called the stress free temperature (temperature at which the structure is not undergoing any stress due to the thermal condition). The change in temperature from that stress-free temperature is what the program needs to know.
As you say, the entire beam undergoes a temperature change. There are 3 points where that is measured - top fiber, centroid, and bottom fiber. That increase causes two effects - axial elongation/contraction, and bending. The axial elongation/contraction is handled thru the term f1 in our earlier answer. The bending effect is handled using f2.
Thanks Mr.Sathia,
The same way I applied temperature load. But all most of the members failed due to the temperature load. Initially the member size is IPE300, then I increase the size into IPE750. But still most members failed. In fact for some of the members the Utilization failure ratio increased. So does it not practical to use temperature load for steel design in STAAD?
For example Member no.6 failure ratio is 1.2 for IPE300 and 1.8 for IPE750
TEMP -62 IPE300.std
