Hi I have a basement slab which is going to support a car park. The basement slab is going to be supported by pile caps. Along the perimeter of the there is a sheet pile wall to mimic this I gave a line support on all sides of the Ram Concept model. I want to know how much the line load coming to these line supports. How can I find that? Please let me know. Thank you
If you model a line support then you can show line support reactions on screen, or in tables. Use the Plot option Reaction - Active - Line Support (or line spring). It's important to note that the program does not envelope line support reactions, so this only works using Context = Standard and thus only for load cases or combinations, not rule sets.
