I have a cantilever w-shape beam that occurs at an HSS column. Does Ram Connection address this?
TIA!
Yes. In RAM Connection, you can assign the following moment connections for a W-shape beam connected to a HSS column:
1. Diaphragm Plate (Smart Connection - Smart FP Bolted or Smart FP Welded)
2. Directly Welded (Smart Connection - Smart DW)
3. Moment End Plate (Smart Connection - Smart MEP HSS). The end plate is welded to the wall of the HSS.
For the diaphragm plate and directly welded connection, a separate shear connection should also be assigned to the joint.
Flange plates directly welded to the face of the HSS (not the side walls like the diaphragm plate) are not available. This is Enhancement #221328 in our database and a connection that we would like to add in the future.
Smart Connection - Smart MEP HSS I'm not able to find this Can anyone help??
