Please see STAAD input command below. I try to change DFF parameter in any value (not 0) but the result still show all member pass all code check.
Please verify if I'm wrong...
Best regard.
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 06-Feb-16END JOB INFORMATIONINPUT WIDTH 79UNIT METER KGJOINT COORDINATES1 0 5 0; 2 10 5 0; 3 0 4.91 1.7; 4 10 4.91 1.7; 5 0 4.93656 1.19832;6 10 4.93656 1.19832; 7 0 3.8 0; 8 10 3.8 0; 9 0 4.99207 0.14979;10 10 4.99207 0.14979; 11 0 4.9511 0.923706; 12 10 4.9511 0.923706;MEMBER INCIDENCES1 1 9; 2 2 10; 3 3 4; 4 5 3; 5 6 4; 6 7 5; 7 8 6; 8 9 11; 9 10 12; 10 9 10;11 11 5; 12 12 6; 13 11 12;START GROUP DEFINITIONFLOOR_CP1 3 TO 5 8 TO 13END GROUP DEFINITIONDEFINE MATERIAL STARTISOTROPIC STEELE 2.09042e+010POISSON 0.3DENSITY 7833.41ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 2.58192e+007 FU 4.1584e+007 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY JAPANESE1 2 4 5 8 9 11 12 TABLE ST C150X75X93 10 13 TABLE ST RHS150X75X2.36 7 TABLE ST C100X50X5CONSTANTSBETA 180 MEMB 2 5 7 9 12MATERIAL STEEL ALLSUPPORTS1 2 7 8 PINNEDLOAD 1 LOADTYPE None TITLE DLSELFWEIGHT Y -1 FLOOR LOAD_CP1 FLOAD -10 GYLOAD 2 LOADTYPE None TITLE LRFLOOR LOAD_CP1 FLOAD -30 GYLOAD 3 LOADTYPE None TITLE WXFLOOR LOAD_CP1 FLOAD 50 GYLOAD 4 LOADTYPE None TITLE WZFLOOR LOAD_CP1 FLOAD 70 GYLOAD COMB 101 DL+LR1 1.0 2 1.0 LOAD COMB 102 DL+0.75[LR+WX]1 1.0 2 0.75 3 0.75 LOAD COMB 103 DL+0.75[LR+WZ]1 1.0 2 0.75 4 0.75LOAD COMB 104 DL+WX1 1.0 3 1.0 LOAD COMB 105 DL+WZ1 1.0 4 1.0 LOAD COMB 106 0.6DL+WX1 0.6 3 1.0 LOAD COMB 107 0.6DL+WZ1 0.6 4 1.0 PERFORM ANALYSISLOAD LIST 101 TO 107PARAMETER 1CODE AISC UNIFIED 2005METHOD ASDMAIN 1 MEMB 3 10 13TMAIN 1 MEMB 3 10 13*LY 5 MEMB 3 10 13DFF 1000 MEMB 3 10 13DJ1 9 MEMB 10DJ2 12 MEMB 10CHECK CODE ALLFINISH
What different of command?. LOAD LIST 101 TO 107 and LOAD LIST ENVELOPE 1 which Envelope 1 include load no. 101 to 107 ? I remember that I ever use this command in SS4 without define any envelope. STAAD can check code and check the deflection.
Does it's mean in the SS6 we must define and evelope for check deflection limit
and for steel design code check we must define envelope or not for the correct result ?.
With most of my code only use LOAD LIST ... TO ... command.
Regard.
Ok sure. Will do. Also just wanted to inform you that whenever we release a new version of STAAD.Pro, the news is published in the STAAD News section that you see when you start up STAAD.Pro as shown next
Please refer to the attached staad file. For example take Beam #133 (T-Support) the deflection ratio is very less. but if you check the relative deflection its huge. Can you please check and revert why its happening. Sometimes when I run the file its shows the failure due to deflection fot the T-support. Request you to update the status ASAP.Sample.std
