Facing Problem Regarding the Anylises of the industrial shed.
Sir i watch your lecture on you tube. I have some problem regarding my project.
I am working on some  project in staad pro which was actually  designed and drafted by structural Engineer .
The project is the design of industrial shed. I am considering all the loads, (wind loads and other loads) which i have to apply on the structure according to the indian codes.
The resultant steel for truss comes very high which will be uneconomical for design prospective view and not match with the designer requirements which they drafted.
If  i have a mistake in truss designing ( regarding the releases of moments or some other operation opration which left) which we have to apply pleases kindly reply.
I declare the members as truss but the results in output is not, what i required. I think, there is some what going wrong to whom i am not known. Please kindly revert me back, that where i have a mistake in file.
####   staad file attached   ####
STAAD SPACE DXF IMPORT OF GRIDE FILE.DXF
START JOB INFORMATION
ENGINEER DATE 01-Feb-16
END JOB INFORMATION
INPUT WIDTH 79
UNIT INCHES NEWTON
JOINT COORDINATES
40 18.8189 252.008 -1108.02; 41 18.8189 252.008 -918.019;
42 18.8189 252.008 -728.019; 43 18.818 252 -538.019;
44 18.8189 252.008 -348.019; 51 801.818 252.008 -348.019;
52 801.818 252 -538.019; 53 801.818 252 -728.019; 54 801.818 252 -918.019;
55 801.811 252.008 -1108.02; 78 410.318 252 -1108.02; 79 320.318 252 -1108.02;
80 230.318 252 -1108.02; 81 140.318 252 -1108.02; 82 50.318 252 -1108.02;
83 500.318 252 -1108.02; 84 590.318 252 -1108.02; 85 680.318 252 -1108.02;
87 410.318 330.787 -1108.02; 88 320.315 312.52 -1108.02;
89 230.315 294.724 -1108.02; 90 140.315 276.22 -1108.02;
91 50.315 258.583 -1108.02; 92 500.318 312.52 -1108.02;
93 590.318 294.724 -1108.02; 94 680.315 276.22 -1108.02;
95 770.315 258.583 -1108.02; 96 95.315 267.402 -1108.02;
97 185.315 285.472 -1108.02; 98 275.315 303.622 -1108.02;
99 365.315 321.654 -1108.02; 100 455.318 321.654 -1108.02;
101 545.318 303.583 -1108.03; 102 635.315 285.472 -1108.02;
103 725.315 267.402 -1108.02; 104 365.318 291.39 -1108.02;
105 455.318 291.39 -1108.02; 132 410.318 252 -918.019;
133 320.318 252 -918.019; 134 230.318 252 -918.019; 135 140.318 252 -918.019;
136 50.318 252 -918.019; 137 500.318 252 -918.019; 138 590.318 252 -918.019;
139 680.318 252 -918.019; 140 770.318 252 -918.019;
141 410.318 330.78 -918.019; 142 365.318 291.39 -918.019;
143 455.318 291.39 -918.019; 144 320.318 312.504 -918.019;
145 230.318 294.72 -918.019; 146 140.318 276.24 -918.019;
147 50.318 258.6 -918.019; 148 500.318 312.504 -918.019;
149 590.318 294.72 -918.019; 150 680.318 276.24 -918.019;
151 770.318 258.6 -918.019; 152 95.318 267.42 -918.019;
153 185.318 285.48 -918.019; 154 275.318 303.612 -918.019;
155 365.318 321.642 -918.019; 156 455.318 321.642 -918.019;
157 545.318 303.612 -918.019; 158 635.318 285.48 -918.019;
159 725.318 267.42 -918.019; 160 410.318 252 -728.019;
161 320.318 252 -728.019; 162 230.318 252 -728.019; 163 140.318 252 -728.019;
164 50.318 252 -728.019; 165 500.318 252 -728.019; 166 590.318 252 -728.019;
167 680.318 252 -728.019; 168 770.318 252 -728.019;
169 410.318 330.78 -728.019; 170 365.318 291.39 -728.019;
171 455.318 291.39 -728.019; 172 320.318 312.504 -728.019;
173 230.318 294.72 -728.019; 174 140.318 276.24 -728.019;
175 50.318 258.6 -728.019; 176 500.318 312.504 -728.019;
177 590.318 294.72 -728.019; 178 680.318 276.24 -728.019;
179 770.318 258.6 -728.019; 180 95.318 267.42 -728.019;
181 185.318 285.48 -728.019; 182 275.318 303.612 -728.019;
183 365.318 321.642 -728.019; 184 455.318 321.642 -728.019;
185 545.318 303.612 -728.019; 186 635.318 285.48 -728.019;
187 725.318 267.42 -728.019; 188 410.318 252 -538.019;
189 320.318 252 -538.019; 190 230.318 252 -538.019; 191 140.318 252 -538.019;
192 50.318 252 -538.019; 193 500.318 252 -538.019; 194 590.318 252 -538.019;
195 680.318 252 -538.019; 196 770.318 252 -538.019;
197 410.318 330.78 -538.019; 198 365.318 291.39 -538.019;
199 455.318 291.39 -538.019; 200 320.318 312.504 -538.019;
201 230.318 294.72 -538.019; 202 140.318 276.24 -538.019;
203 50.315 258.6 -538.019; 204 500.318 312.504 -538.019;
205 590.318 294.72 -538.019; 206 680.318 276.24 -538.019;
207 770.318 258.6 -538.019; 208 95.318 267.42 -538.019;
209 185.318 285.48 -538.019; 210 275.318 303.612 -538.019;
211 365.318 321.642 -538.019; 212 455.318 321.642 -538.019;
213 545.318 303.612 -538.019; 214 635.318 285.48 -538.019;
215 725.318 267.42 -538.019; 216 410.318 252 -348.019;
217 320.318 252 -348.019; 218 230.318 252 -348.019; 219 140.318 252 -348.019;
220 50.318 252 -348.019; 221 500.318 252 -348.019; 222 590.318 252 -348.019;
223 680.318 252 -348.019; 224 770.318 252 -348.019;
225 410.318 330.787 -348.019; 226 365.318 291.39 -348.019;
227 455.318 291.39 -348.019; 228 320.318 312.52 -348.019;
229 230.315 294.724 -348.019; 230 140.315 276.22 -348.019;
231 50.3181 258.583 -348.019; 232 500.318 312.52 -348.019;
233 590.318 294.685 -348.032; 234 680.318 276.22 -348.019;
235 770.318 258.583 -348.019; 236 95.315 267.402 -348.019;
237 185.315 285.472 -348.019; 238 275.315 303.622 -348.019;
239 365.315 321.654 -348.019; 240 455.318 321.654 -348.019;
241 545.318 303.622 -348.019; 242 635.318 285.472 -348.032;
243 725.318 267.402 -348.019; 341 770.318 252 -1108.02;
MEMBER INCIDENCES
98 78 79; 99 79 80; 100 80 81; 101 81 82; 102 40 82; 103 78 83; 104 83 84;
105 84 85; 108 78 87; 111 79 104; 112 87 105; 113 79 88; 114 80 89; 115 81 90;
116 82 91; 117 83 92; 118 84 93; 119 85 94; 121 40 91; 122 91 96; 123 90 97;
124 89 98; 125 88 99; 126 87 100; 127 92 101; 128 93 102; 129 94 103;
130 95 55; 131 96 90; 132 97 89; 133 98 88; 134 99 87; 135 100 92; 136 101 93;
137 102 94; 138 103 95; 139 82 96; 140 96 81; 141 81 97; 142 97 80; 143 80 98;
144 98 79; 145 83 101; 146 101 84; 147 84 102; 148 102 85; 149 85 103;
151 104 87; 152 105 83; 153 88 104; 154 99 104; 155 105 92; 156 100 105;
224 132 133; 225 133 134; 226 134 135; 227 135 136; 228 41 136; 229 132 137;
230 137 138; 231 138 139; 232 139 140; 233 140 54; 234 132 141; 235 133 142;
236 141 143; 237 133 144; 238 134 145; 239 135 146; 240 136 147; 241 137 148;
242 138 149; 243 139 150; 244 140 151; 245 41 147; 246 147 152; 247 146 153;
248 145 154; 249 144 155; 250 141 156; 251 148 157; 252 149 158; 253 150 159;
254 151 54; 255 152 146; 256 153 145; 257 154 144; 258 155 141; 259 156 148;
260 157 149; 261 158 150; 262 159 151; 263 136 152; 264 152 135; 265 135 153;
266 153 134; 267 134 154; 268 154 133; 269 137 157; 270 157 138; 271 138 158;
272 158 139; 273 139 159; 274 159 140; 275 142 141; 276 143 137; 277 144 142;
278 155 142; 279 143 148; 280 156 143; 281 160 161; 282 161 162; 283 162 163;
284 163 164; 285 42 164; 286 160 165; 287 165 166; 288 166 167; 289 167 168;
290 168 53; 291 160 169; 292 161 170; 293 169 171; 294 161 172; 295 162 173;
296 163 174; 297 164 175; 298 165 176; 299 166 177; 300 167 178; 301 168 179;
302 42 175; 303 175 180; 304 174 181; 305 173 182; 306 172 183; 307 169 184;
308 176 185; 309 177 186; 310 178 187; 311 179 53; 312 180 174; 313 181 173;
314 182 172; 315 183 169; 316 184 176; 317 185 177; 318 186 178; 319 187 179;
320 164 180; 321 180 163; 322 163 181; 323 181 162; 324 162 182; 325 182 161;
326 165 185; 327 185 166; 328 166 186; 329 186 167; 330 167 187; 331 187 168;
332 170 169; 333 171 165; 334 172 170; 335 183 170; 336 171 176; 337 184 171;
338 188 189; 339 189 190; 340 190 191; 341 191 192; 342 43 192; 343 188 193;
344 193 194; 345 194 195; 346 195 196; 347 196 52; 348 188 197; 349 189 198;
350 197 199; 351 189 200; 352 190 201; 353 191 202; 354 192 203; 355 193 204;
356 194 205; 357 195 206; 358 196 207; 359 43 203; 360 203 208; 361 202 209;
362 201 210; 363 200 211; 364 197 212; 365 204 213; 366 205 214; 367 206 215;
368 207 52; 369 208 202; 370 209 201; 371 210 200; 372 211 197; 373 212 204;
374 213 205; 375 214 206; 376 215 207; 377 192 208; 378 208 191; 379 191 209;
380 209 190; 381 190 210; 382 210 189; 383 193 213; 384 213 194; 385 194 214;
386 214 195; 387 195 215; 388 215 196; 389 198 197; 390 199 193; 391 200 198;
392 211 198; 393 199 204; 394 212 199; 395 216 217; 396 217 218; 397 218 219;
398 219 220; 399 44 220; 400 216 221; 401 221 222; 402 222 223; 403 223 224;
404 224 51; 405 216 225; 406 217 226; 407 225 227; 408 217 228; 409 218 229;
410 219 230; 411 220 231; 412 221 232; 413 222 233; 414 223 234; 415 224 235;
416 44 231; 417 231 236; 418 230 237; 419 229 238; 420 228 239; 421 225 240;
422 232 241; 423 233 242; 424 234 243; 425 235 51; 426 236 230; 427 237 229;
428 238 228; 429 239 225; 430 240 232; 431 241 233; 432 242 234; 433 243 235;
434 220 236; 435 236 219; 436 219 237; 437 237 218; 438 218 238; 439 238 217;
440 221 241; 441 241 222; 442 222 242; 443 242 223; 444 223 243; 445 243 224;
446 226 225; 447 227 221; 448 228 226; 449 239 226; 450 227 232; 451 240 227;
517 87 141; 518 141 169; 519 169 197; 520 197 225; 554 159 103; 555 150 94;
556 158 102; 557 149 93; 558 157 101; 559 148 92; 560 156 100; 561 155 99;
562 144 88; 563 154 98; 564 145 89; 565 153 97; 566 146 90; 567 152 96;
568 147 91; 569 175 147; 570 180 152; 571 174 146; 572 181 153; 573 173 145;
574 182 154; 575 172 144; 576 183 155; 577 184 156; 578 176 148; 579 185 157;
580 177 149; 581 186 158; 582 178 150; 583 187 159; 584 179 151; 585 207 179;
586 215 187; 587 206 178; 588 214 186; 589 205 177; 590 213 185; 591 204 176;
592 212 184; 593 211 183; 594 200 172; 595 210 182; 596 201 173; 597 209 181;
598 202 174; 599 208 180; 600 203 175; 601 235 207; 602 243 215; 603 234 206;
604 242 214; 605 233 205; 606 241 213; 607 232 204; 608 240 212; 609 239 211;
610 228 200; 611 238 210; 612 229 201; 613 237 209; 614 230 202; 615 236 208;
616 231 203; 649 95 151; 689 85 341; 691 341 55; 692 95 341; 693 103 341;
696 81 135; 697 135 163; 698 163 191; 699 191 219; 712 218 190; 713 190 162;
714 162 134; 715 134 80; 716 79 133; 717 133 161; 718 161 189; 719 217 189;
720 193 221; 721 194 222; 722 195 223; 723 167 195; 724 166 194; 725 165 193;
726 137 165; 727 138 166; 728 139 167; 729 85 139; 730 84 138; 731 83 137;
START GROUP DEFINITION
FLOOR
_A 121
_A1 122
_A2 131
_A3 123
_A4 132
_A5 124
_A6 133
_A7 134
_A8 126
_A9 135
_A10 127
_A11 136
_A12 128
_A13 137
_A14 129
_A15 138
_A16 130
_B1 121 245 568
_B2 122 246 567 568
_B3 131 255 566 567
_B4 123 247 565 566
_B5 132 256 564 565
_B6 124 248 563 564
_B7 133 257 562 563
_B8 125 249 561 562
_B9 134 258 517 561
_B10 126 250 517 560
_B11 135 259 559 560
_B12 127 251 558 559
_B13 136 260 557 558
_B14 128 252 556 557
_B15 137 261 555 556
_B16 129 253 554 555
_B17 138 262 554 649
_B18 130 254 649
_C2 246 303 569 570
_C3 255 312 570 571
_C4 247 304 571 572
_C5 256 313 572 573
_C6 248 305 573 574
_C7 257 314 574 575
_C8 249 306 575 576
_C9 258 315 518 576
_C10 250 307 518 577
_C11 259 316 577 578
_C12 251 308 578 579
_C13 260 317 579 580
_C14 252 309 580 581
_C15 261 318 581 582
_C16 253 310 582 583
_C17 262 319 583 584
_C18 254 311 584
_D1 302 359 600
_D2 303 360 599 600
_D3 312 369 598 599
_D4 304 361 597 598
_D5 313 370 596 597
_D6 305 362 595 596
_D7 314 371 594 595
_D8 306 363 593 594
_D9 315 372 519 593
_D10 307 364 519 592
_D11 316 373 591 592
_D12 308 365 590 591
_D13 317 374 589 590
_D14 309 366 588 589
_D15 318 375 587 588
_D16 310 367 586 587
_D17 319 376 585 586
_D18 311 368 585
_Q1 359 416 616
_Q2 360 417 615 616
_Q3 369 426 614 615
_Q4 361 418 613 614
_Q5 370 427 612 613
_Q6 362 419 611 612
_Q7 371 428 610 611
_Q8 363 420 609 610
_Q9 372 429 520 609
_Q10 364 421 520 608
_Q11 373 430 607 608
_Q12 365 422 606 607
_Q13 374 431 605 606
_Q14 366 423 604 605
_Q15 375 432 603 604
_Q16 367 424 602 603
_Q17 376 433 601 602
_Q18 368 425 601
_W1 416
_W2 417
_W3 426
_W4 418
_W5 427
_W6 419
_W7 428
_W8 420
_W9 429
_W10 421
_W11 430
_W12 422
_W13 431
_W14 423
_W15 432
_W16 424
_W17 433
_W18 425
_C1 245 302 569
JOINT
END GROUP DEFINITION
UNIT METER KN
DEFINE MATERIAL START
ISOTROPIC CONCRETE
E 2.17185e+007
POISSON 0.17
DENSITY 23.5616
ALPHA 1e-005
DAMP 0.05
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
END DEFINE MATERIAL
MEMBER PROPERTY INDIAN
115 119 139 140 149 153 TO 156 239 243 263 264 273 274 277 TO 280 296 300 -
320 321 330 331 334 TO 337 353 357 377 378 387 388 391 TO 394 410 414 434 -
435 444 445 448 TO 451 693 696 TO 699 712 TO 731 TABLE ST ISA75X75X6
98 TO 105 121 TO 138 224 TO 233 245 TO 262 281 TO 290 302 TO 319 338 TO 347 -
359 TO 376 395 TO 404 416 TO 433 689 691 TABLE LD ISA90X90X8
116 240 244 297 301 354 358 411 415 692 TABLE ST ISA50X50X6
108 111 TO 114 117 118 141 TO 148 151 152 234 TO 238 241 242 265 TO 272 275 -
276 291 TO 295 298 299 322 TO 329 332 333 348 TO 352 355 356 379 TO 386 389 -
390 405 TO 409 412 413 436 TO 443 446 447 TABLE LD ISA75X75X6
517 TO 520 554 TO 616 649 TABLE ST ISMC150
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
40 TO 44 FIXED
51 TO 55 FIXED BUT FX FZ MX MY MZ
MEMBER TRUSS
98 TO 105 108 111 TO 119 121 TO 149 151 TO 156 224 TO 451 517 TO 520 -
554 TO 616 649 689 691 TO 693 696 TO 699 712 TO 731
DEFINE WIND LOAD
TYPE 1
<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!
ASCE-7-2002:PARAMS 47.000 mph 0 1 1 0 0.000 ft 0.000 ft 0.000 ft 1 -
2 30.000 ft 30.000 ft 25.000 ft 2.000 0.010 0 -
0 0 0 0 0.701 1.000 1.000 0.850 0 -
0 0 0 0.871 0.800 0.180
!> END GENERATED DATA BLOCK
INT 0.478803 0.478803 0.478803 0.478803 0.478803 0.478803 0.478803 0.478803 -
0.478803 0.478803 0.478803 0.478803 0.478803 0.478803 0.478803 HEIG 0 4.572 -
4.92369 5.27538 5.62708 5.97877 6.33046 6.68215 7.03385 7.38554 -
7.73723 8.08892 8.44062 8.79231 9.144
EXP 1 JOINT 40 TO 44 51 TO 55 78 TO 85 87 TO 105 132 TO 243 341
*DEFINE WIND LOAD
*TYPE 1
*INT 30.3728 HEIG 10
*EXP 0.5 JOINT 5 TO 15 20 TO 30 35 TO 45 50 TO 66 68 TO 85 87 TO 107 -
*109 TO 118 123 TO 250 252 TO 257 261 TO 340
*LOAD 1 LOADTYPE Wind TITLE WIND
*WIND LOAD X 1 TYPE 1 YR 0 10
*WIND LOAD Z 1 TYPE 1 YR 0 10
*WIND LOAD -X 1 TYPE 1 YR 0 10
*WIND LOAD -Z 1 TYPE 1 YR 0 10
LOAD 1 LOADTYPE Dead TITLE DEAD
SELFWEIGHT Y -1 LIST 98 TO 105 108 111 TO 119 121 TO 149 151 TO 156 -
224 TO 451 517 TO 520 554 TO 616 649 689 691 TO 693 696 TO 699 712 TO 731
FLOOR LOAD
_A FLOAD -0.2 GY INCLINED
_A1 FLOAD -0.2 GY INCLINED
_A2 FLOAD -0.2 GY INCLINED
_A3 FLOAD -0.2 GY INCLINED
_A4 FLOAD -0.2 GY INCLINED
_A5 FLOAD -0.2 GY INCLINED
_A6 FLOAD -0.2 GY INCLINED
_A7 FLOAD -0.2 GY INCLINED
_A8 FLOAD -0.2 GY INCLINED
_A9 FLOAD -0.2 GY INCLINED
_A10 FLOAD -0.2 GY INCLINED
_A11 FLOAD -0.2 GY INCLINED
_A12 FLOAD -0.2 GY INCLINED
_A13 FLOAD -0.2 GY INCLINED
_A14 FLOAD -0.2 GY INCLINED
_A15 FLOAD -0.2 GY INCLINED
_A16 FLOAD -0.2 GY INCLINED
_B1 FLOAD -0.2 GY INCLINED
_B2 FLOAD -0.2 GY INCLINED
_B3 FLOAD -0.2 GY INCLINED
_B4 FLOAD -0.2 GY INCLINED
_B5 FLOAD -0.2 GY INCLINED
_B6 FLOAD -0.2 GY INCLINED
_B7 FLOAD -0.2 GY INCLINED
_B8 FLOAD -0.2 GY INCLINED
_B9 FLOAD -0.2 GY INCLINED
_B10 FLOAD -0.2 GY INCLINED
_B11 FLOAD -0.2 GY INCLINED
_B12 FLOAD -0.2 GY INCLINED
_B13 FLOAD -0.2 GY INCLINED
_B14 FLOAD -0.2 GY INCLINED
_B15 FLOAD -0.2 GY INCLINED
_B16 FLOAD -0.2 GY INCLINED
_B17 FLOAD -0.2 GY INCLINED
_B18 FLOAD -0.2 GY INCLINED
_C1 FLOAD -0.2 GY INCLINED
_C2 FLOAD -0.2 GY INCLINED
_C3 FLOAD -0.2 GY INCLINED
_C4 FLOAD -0.2 GY INCLINED
_C5 FLOAD -0.2 GY INCLINED
_C6 FLOAD -0.2 GY INCLINED
_C7 FLOAD -0.2 GY INCLINED
_C8 FLOAD -0.2 GY INCLINED
_C9 FLOAD -0.2 GY INCLINED
_C10 FLOAD -0.2 GY INCLINED
_C11 FLOAD -0.2 GY INCLINED
_C12 FLOAD -0.2 GY INCLINED
_C13 FLOAD -0.2 GY INCLINED
_C14 FLOAD -0.2 GY INCLINED
_C15 FLOAD -0.2 GY INCLINED
_C16 FLOAD -0.2 GY INCLINED
_C17 FLOAD -0.2 GY INCLINED
_C18 FLOAD -0.2 GY INCLINED
_D1 FLOAD -0.2 GY INCLINED
_D2 FLOAD -0.2 GY INCLINED
_D3 FLOAD -0.2 GY INCLINED
_D4 FLOAD -0.2 GY INCLINED
_D5 FLOAD -0.2 GY INCLINED
_D6 FLOAD -0.2 GY INCLINED
_D7 FLOAD -0.2 GY INCLINED
_D8 FLOAD -0.2 GY INCLINED
_D9 FLOAD -0.2 GY INCLINED
_D10 FLOAD -0.2 GY INCLINED
_D11 FLOAD -0.2 GY INCLINED
_D12 FLOAD -0.2 GY INCLINED
_D13 FLOAD -0.2 GY INCLINED
_D14 FLOAD -0.2 GY INCLINED
_D15 FLOAD -0.2 GY INCLINED
_D16 FLOAD -0.2 GY INCLINED
_D17 FLOAD -0.2 GY INCLINED
_D18 FLOAD -0.2 GY INCLINED
_Q1 FLOAD -0.2 GY INCLINED
_Q2 FLOAD -0.2 GY INCLINED
_Q3 FLOAD -0.2 GY INCLINED
_Q4 FLOAD -0.2 GY INCLINED
_Q5 FLOAD -0.2 GY INCLINED
_Q6 FLOAD -0.2 GY INCLINED
_Q7 FLOAD -0.2 GY INCLINED
_Q9 FLOAD -0.2 GY INCLINED
_Q10 FLOAD -0.2 GY INCLINED
_Q12 FLOAD -0.2 GY INCLINED
_Q13 FLOAD -0.2 GY INCLINED
_Q14 FLOAD -0.2 GY INCLINED
_Q15 FLOAD -0.2 GY INCLINED
_Q16 FLOAD -0.2 GY INCLINED
_Q17 FLOAD -0.2 GY INCLINED
_Q18 FLOAD -0.2 GY INCLINED
_W1 FLOAD -0.2 GY INCLINED
_W2 FLOAD -0.2 GY INCLINED
_W3 FLOAD -0.2 GY INCLINED
_W4 FLOAD -0.2 GY INCLINED
_W5 FLOAD -0.2 GY INCLINED
_W6 FLOAD -0.2 GY INCLINED
_W7 FLOAD -0.2 GY INCLINED
_W8 FLOAD -0.2 GY INCLINED
_W9 FLOAD -0.2 GY INCLINED
_W10 FLOAD -0.2 GY INCLINED
_W11 FLOAD -0.2 GY INCLINED
_W12 FLOAD -0.2 GY INCLINED
_W13 FLOAD -0.2 GY INCLINED
_W14 FLOAD -0.2 GY INCLINED
_W15 FLOAD -0.2 GY INCLINED
_W16 FLOAD -0.2 GY INCLINED
_W17 FLOAD -0.2 GY INCLINED
_W18 FLOAD -0.2 GY INCLINED
YRANGE 5 6.5 FLOAD -0.2 GY
**_AA FLOAD -4.5 GY
*_AA1 FLOAD -4.5 GY
*_AA2 FLOAD -4.5 GY
*_QQ1 FLOAD -4.5 GY
*_QQ2 FLOAD -4.5 GY
*_QQ3 FLOAD -4.5 GY
LOAD 2 LOADTYPE Live REDUCIBLE TITLE LIVE
FLOOR LOAD
_A FLOAD -0.75 GY INCLINED
_A1 FLOAD -0.75 GY INCLINED
_A2 FLOAD -0.75 GY INCLINED
_A3 FLOAD -0.75 GY INCLINED
_A4 FLOAD -0.75 GY INCLINED
_A5 FLOAD -0.75 GY INCLINED
_A6 FLOAD -0.75 GY INCLINED
_A7 FLOAD -0.75 GY INCLINED
_A8 FLOAD -0.75 GY INCLINED
_A9 FLOAD -0.75 GY INCLINED
_A10 FLOAD -0.75 GY INCLINED
_A11 FLOAD -0.75 GY INCLINED
_A12 FLOAD -0.75 GY INCLINED
_A13 FLOAD -0.75 GY INCLINED
_A14 FLOAD -0.75 GY INCLINED
_A15 FLOAD -0.75 GY INCLINED
_A16 FLOAD -0.75 GY INCLINED
_B1 FLOAD -0.75 GY INCLINED
_B2 FLOAD -0.75 GY INCLINED
_B3 FLOAD -0.75 GY INCLINED
_B4 FLOAD -0.75 GY INCLINED
_B5 FLOAD -0.75 GY INCLINED
_B6 FLOAD -0.75 GY INCLINED
_B7 FLOAD -0.75 GY INCLINED
_B8 FLOAD -0.75 GY INCLINED
_B9 FLOAD -0.75 GY INCLINED
_B10 FLOAD -0.75 GY INCLINED
_B11 FLOAD -0.75 GY INCLINED
_B12 FLOAD -0.75 GY INCLINED
_B13 FLOAD -0.75 GY INCLINED
_B14 FLOAD -0.75 GY INCLINED
_B15 FLOAD -0.75 GY INCLINED
_B16 FLOAD -0.75 GY INCLINED
_B17 FLOAD -0.75 GY INCLINED
_B18 FLOAD -0.75 GY INCLINED
_C1 FLOAD -0.75 GY INCLINED
_C2 FLOAD -0.75 GY INCLINED
_C3 FLOAD -0.75 GY INCLINED
_C4 FLOAD -0.75 GY INCLINED
_C5 FLOAD -0.75 GY INCLINED
_C6 FLOAD -0.75 GY INCLINED
_C7 FLOAD -0.75 GY INCLINED
_C8 FLOAD -0.75 GY INCLINED
_C9 FLOAD -0.75 GY INCLINED
_C10 FLOAD -0.75 GY INCLINED
_C11 FLOAD -0.75 GY INCLINED
_C12 FLOAD -0.75 GY INCLINED
_C13 FLOAD -0.75 GY INCLINED
_C14 FLOAD -0.75 GY INCLINED
_C15 FLOAD -0.75 GY INCLINED
_C16 FLOAD -0.75 GY INCLINED
_C17 FLOAD -0.75 GY INCLINED
_C18 FLOAD -0.75 GY INCLINED
_D1 FLOAD -0.75 GY INCLINED
_D2 FLOAD -0.75 GY INCLINED
_D3 FLOAD -0.75 GY INCLINED
_D4 FLOAD -0.75 GY INCLINED
_D5 FLOAD -0.75 GY INCLINED
_D6 FLOAD -0.75 GY INCLINED
_D7 FLOAD -0.75 GY INCLINED
_D8 FLOAD -0.75 GY INCLINED
_D9 FLOAD -0.75 GY INCLINED
_D10 FLOAD -0.75 GY INCLINED
_D11 FLOAD -0.75 GY INCLINED
_D12 FLOAD -0.75 GY INCLINED
_D13 FLOAD -0.75 GY INCLINED
_D14 FLOAD -0.75 GY INCLINED
_D15 FLOAD -0.75 GY INCLINED
_D16 FLOAD -0.75 GY INCLINED
_D17 FLOAD -0.75 GY INCLINED
_D18 FLOAD -0.75 GY INCLINED
_Q1 FLOAD -0.75 GY INCLINED
_Q2 FLOAD -0.75 GY INCLINED
_Q3 FLOAD -0.75 GY INCLINED
_Q4 FLOAD -0.75 GY INCLINED
_Q5 FLOAD -0.75 GY INCLINED
_Q6 FLOAD -0.75 GY INCLINED
_Q7 FLOAD -0.75 GY INCLINED
_Q8 FLOAD -0.75 GY INCLINED
_Q9 FLOAD -0.75 GY INCLINED
_Q10 FLOAD -0.75 GY INCLINED
_Q11 FLOAD -0.75 GY INCLINED
_Q12 FLOAD -0.75 GY INCLINED
_Q13 FLOAD -0.75 GY INCLINED
_Q14 FLOAD -0.75 GY INCLINED
_Q15 FLOAD -0.75 GY INCLINED
_Q16 FLOAD -0.75 GY INCLINED
_Q17 FLOAD -0.75 GY INCLINED
_Q18 FLOAD -0.75 GY INCLINED
_W1 FLOAD -0.75 GY INCLINED
_W2 FLOAD -0.75 GY INCLINED
_W3 FLOAD -0.75 GY INCLINED
_W4 FLOAD -0.75 GY INCLINED
_W5 FLOAD -0.75 GY INCLINED
_W6 FLOAD -0.75 GY INCLINED
_W7 FLOAD -0.75 GY INCLINED
_W8 FLOAD -0.75 GY INCLINED
_W9 FLOAD -0.75 GY INCLINED
_W10 FLOAD -0.75 GY INCLINED
_W11 FLOAD -0.75 GY INCLINED
_W12 FLOAD -0.75 GY INCLINED
_W14 FLOAD -0.75 GY INCLINED
_W15 FLOAD -0.75 GY INCLINED
_W16 FLOAD -0.75 GY INCLINED
_W17 FLOAD -0.75 GY INCLINED
_W18 FLOAD -0.75 GY INCLINED
LOAD 3 LOADTYPE Wind TITLE LOAD CASE 3
WIND LOAD X 1 TYPE 1 YR 0 12
WIND LOAD Z 1 TYPE 1 YR 0 12
WIND LOAD -X 1 TYPE 1 YR 0 12
WIND LOAD -Z 1 TYPE 1 YR 0 12
LOAD COMB 4 Generated Indian Code Steel_Plastic 1
1 1.7 2 1.7
LOAD COMB 5 Generated Indian Code Steel_Plastic 2
1 1.7
LOAD COMB 6 Generated Indian Code Steel_Plastic 3
1 1.3 2 1.3
LOAD COMB 7 Generated Indian Code Steel_Plastic 4
1 1.7 3 1.7
LOAD COMB 8 Generated Indian Code Steel_Plastic 5
1 1.7 3 -1.7
LOAD COMB 9 Generated Indian Code Steel_Plastic 6
1 1.3 2 1.3 3 1.3
LOAD COMB 10 Generated Indian Code Steel_Plastic 7
1 1.3 2 1.3 3 -1.3
**_AA FLOAD -3 GY
*_AA1 FLOAD -3 GY
*_AA2 FLOAD -3 GY
*_QQ1 FLOAD -3 GY
*_QQ2 FLOAD -3 GY
*_QQ3 FLOAD -3 GY
*LOAD 1 LOADTYPE Wind TITLE LOAD CASE 1
**LOAD 2 LOADTYPE Wind TITLE LOAD CASE 2
PERFORM ANALYSIS PRINT ALL
PARAMETER 1
CODE INDIAN
CHECK CODE MEMB 98 TO 105 108 111 TO 119 121 TO 149 151 TO 156 224 TO 451 -
PARAMETER 2
CODE INDIAN
STEEL MEMBER TAKE OFF LIST 98 TO 105 108 111 TO 119 121 TO 149 151 TO 156 -
START CONCRETE DESIGN
CODE INDIAN
CONCRETE TAKE
END CONCRETE DESIGN
*PARAMETER 4
*CODE INDIAN
*SELECT OPTIMIZED
FINISH
  • I have reviewed your model and noticed the following problems--
    1. Specification -- You have specified several members in your model as truss member. Due to that, there are several instability warnings. You can define the members as truss members by partially releasing the moments at the start and the end nodes. You can go through the following post for more details-
    communities.bentley.com/.../staad-pro-instability-and-zero-stiffness-faq.aspx
    2. Load -- You have created several Floor Groups with a single member assigned to that group (for example, Gourp A to A16), and used that group to apply floor load. A floor group should be defined as a closed panel. So program is unable to apply the load on that group and there are several error messages.
    You have generated the wind load intensity as per ASCE code. You need to recheck the height vs. intensity data as per IS875-Part 3 specifications.
    3. Load Combination -- The combination factor that you have used is not correct. You need to use the combination factors used in Table 4 of IS800:2007 code.
    4. Design Code -- You have used factored load combination cases but used WSD code (IS800:1984) to design the members. If you want to use limit stated method of design (IS800:2007), you need to change the code to CODE INDIAN LSD. Else use unfactoed load combination cases for the design.
  • I have worked over the recommendation made by you on my model.
    1. I define the members as truss members by partially releasing the moments at the start and the end nodes.
    2. Load -- floor group should be defined as a closed panel.
    3. check the height vs. intensity data as per IS875-Part 3 specifications.
    3. Load Combination factore are according to the steel plastic auto load combinations
    4. Changed the Design Code to Is 800:2007
    But know i have some other errors in the file LIKE.
    **ERROR: TRUSS/CABLE/TENSION/COMPRESSION MEMBER 124 IN MEMBER RELEASE COMMAND.
    please help me regarding this. i will be very thankful to you.
    STAAD plane DXF IMPORT OF GRIDE FILE.DXF
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT INCHES NEWTON
    JOINT COORDINATES
    MEMBER INCIDENCES
    FLOOR
    *_A 121
    *_A1 122
    *_A2 131
    *_A3 123
    *_A4 132
    *_A5 124
    *_A6 133
    *_A7 134
    *_A8 126
    *_A9 135
    *_A10 127
    *_A11 136
    *_A12 128
    *_A13 137
    *_A14 129
    *_A15 138
    *_A16 130
    _B1 121 245 568
    _B2 122 246 567 568
    _B3 131 255 566 567
    _B4 123 247 565 566
    _B5 132 256 564 565
    _B6 124 248 563 564
    _B7 133 257 562 563
    _B8 125 249 561 562
    _B9 134 258 517 561
    _B18 130 254 649
    _C2 246 303 569 570
    _C3 255 312 570 571
    _C4 247 304 571 572
    _C5 256 313 572 573
    _C6 248 305 573 574
    _C7 257 314 574 575
    _C8 249 306 575 576
    _C9 258 315 518 576
    _C18 254 311 584
    _D1 302 359 600
    _D2 303 360 599 600
    _D3 312 369 598 599
    _D4 304 361 597 598
    _D5 313 370 596 597
    _D6 305 362 595 596
    _D7 314 371 594 595
    _D8 306 363 593 594
    _D9 315 372 519 593
    _D18 311 368 585
    _Q1 359 416 616
    _Q2 360 417 615 616
    _Q3 369 426 614 615
    _Q4 361 418 613 614
    _Q5 370 427 612 613
    _Q6 362 419 611 612
    _Q7 371 428 610 611
    _Q8 363 420 609 610
    _Q9 372 429 520 609
    _Q18 368 425 601
    *_W1 416
    *_W2 417
    *_W3 426
    *_W4 418
    *_W5 427
    *_W6 419
    *_W7 428
    *_W8 420
    *_W9 429
    *_W10 421
    *_W11 430
    *_W12 422
    *_W13 431
    *_W14 423
    *_W15 432
    *_W16 424
    *_W17 433
    *_W18 425
    _C1 245 302 569
    JOINT
    UNIT METER KN
    ISOTROPIC CONCRETE
    E 2.17185e+007
    POISSON 0.17
    DENSITY 23.5616
    ALPHA 1e-005
    DAMP 0.05
    ISOTROPIC STEEL
    E 2.05e+008
    POISSON 0.3
    DENSITY 76.8195
    ALPHA 1.2e-005
    DAMP 0.03
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL STEEL ALL
    SUPPORTS
    40 TO 44 FIXED
    MEMBER TRUSS
    MEMBER RELEASE
    554 TO 616 649 689 691 TO 693 696 TO 699 712 TO 730 -
    731 START MPX 0.95 MPY 0.75 MPZ 0.5
    731 END MPX 0.95 MPY 0.75 MPZ 0.5
    DEFINE WIND LOAD
    TYPE 1
    ASCE-7-2002:PARAMS 47.000 MPH 0 1 1 0 0.000 FT 0.000 FT 0.000 FT 1 -
    2 30.000 FT 30.000 FT 25.000 FT 2.000 0.010 0 -
    *DEFINE WIND LOAD
    *TYPE 1
    SELFWEIGHT Y -1 LIST ALL
    FLOOR LOAD
    *_A FLOAD -0.2 GY INCLINED
    *_A1 FLOAD -0.2 GY INCLINED
    *_A2 FLOAD -0.2 GY INCLINED
    *_A3 FLOAD -0.2 GY INCLINED
    *_A4 FLOAD -0.2 GY INCLINED
    *_A5 FLOAD -0.2 GY INCLINED
    *_A6 FLOAD -0.2 GY INCLINED
    *_A7 FLOAD -0.2 GY INCLINED
    *_A8 FLOAD -0.2 GY INCLINED
    *_A9 FLOAD -0.2 GY INCLINED
    *_A10 FLOAD -0.2 GY INCLINED
    *_A11 FLOAD -0.2 GY INCLINED
    *_A12 FLOAD -0.2 GY INCLINED
    *_A13 FLOAD -0.2 GY INCLINED
    *_A14 FLOAD -0.2 GY INCLINED
    *_A15 FLOAD -0.2 GY INCLINED
    *_A16 FLOAD -0.2 GY INCLINED
    *_W1 FLOAD -0.2 GY INCLINED
    *_W2 FLOAD -0.2 GY INCLINED
    *_W3 FLOAD -0.2 GY INCLINED
    *_W4 FLOAD -0.2 GY INCLINED
    *_W5 FLOAD -0.2 GY INCLINED
    *_W6 FLOAD -0.2 GY INCLINED
    *_W7 FLOAD -0.2 GY INCLINED
    *_W8 FLOAD -0.2 GY INCLINED
    *_W9 FLOAD -0.2 GY INCLINED
    *_W10 FLOAD -0.2 GY INCLINED
    *_W11 FLOAD -0.2 GY INCLINED
    *_W12 FLOAD -0.2 GY INCLINED
    *_W13 FLOAD -0.2 GY INCLINED
    *_W14 FLOAD -0.2 GY INCLINED
    *_W15 FLOAD -0.2 GY INCLINED
    *_W16 FLOAD -0.2 GY INCLINED
    *_W17 FLOAD -0.2 GY INCLINED
    *_W18 FLOAD -0.2 GY INCLINED
    **_AA FLOAD -4.5 GY
    *_AA1 FLOAD -4.5 GY
    *_AA2 FLOAD -4.5 GY
    *_QQ1 FLOAD -4.5 GY
    *_QQ2 FLOAD -4.5 GY
    *_QQ3 FLOAD -4.5 GY
    FLOOR LOAD
    *_A FLOAD -0.75 GY INCLINED
    *_A1 FLOAD -0.75 GY INCLINED
    *_A2 FLOAD -0.75 GY INCLINED
    *_A3 FLOAD -0.75 GY INCLINED
    *_A4 FLOAD -0.75 GY INCLINED
    *_A5 FLOAD -0.75 GY INCLINED
    *_A6 FLOAD -0.75 GY INCLINED
    *_A7 FLOAD -0.75 GY INCLINED
    *_A8 FLOAD -0.75 GY INCLINED
    *_A9 FLOAD -0.75 GY INCLINED
    *_A10 FLOAD -0.75 GY INCLINED
    *_A11 FLOAD -0.75 GY INCLINED
    *_A12 FLOAD -0.75 GY INCLINED
    *_A13 FLOAD -0.75 GY INCLINED
    *_A14 FLOAD -0.75 GY INCLINED
    *_A15 FLOAD -0.75 GY INCLINED
    *_A16 FLOAD -0.75 GY INCLINED
    *_W1 FLOAD -0.75 GY INCLINED
    *_W2 FLOAD -0.75 GY INCLINED
    *_W3 FLOAD -0.75 GY INCLINED
    *_W4 FLOAD -0.75 GY INCLINED
    *_W5 FLOAD -0.75 GY INCLINED
    *_W6 FLOAD -0.75 GY INCLINED
    *_W7 FLOAD -0.75 GY INCLINED
    *_W8 FLOAD -0.75 GY INCLINED
    *_W9 FLOAD -0.75 GY INCLINED
    *_W10 FLOAD -0.75 GY INCLINED
    *_W11 FLOAD -0.75 GY INCLINED
    *_W12 FLOAD -0.75 GY INCLINED
    *_W14 FLOAD -0.75 GY INCLINED
    *_W15 FLOAD -0.75 GY INCLINED
    *_W16 FLOAD -0.75 GY INCLINED
    *_W17 FLOAD -0.75 GY INCLINED
    *_W18 FLOAD -0.75 GY INCLINED
    LOAD COMB 4 GENERATED INDIAN CODE STEEL_PLASTIC 1
    1 1.7 2 1.7
    LOAD COMB 5 GENERATED INDIAN CODE STEEL_PLASTIC 2
    1 1.7
    LOAD COMB 6 GENERATED INDIAN CODE STEEL_PLASTIC 3
    1 1.3 2 1.3
    LOAD COMB 7 GENERATED INDIAN CODE STEEL_PLASTIC 4
    1 1.7 3 1.7
    LOAD COMB 8 GENERATED INDIAN CODE STEEL_PLASTIC 5
    1 1.7 3 -1.7
    LOAD COMB 9 GENERATED INDIAN CODE STEEL_PLASTIC 6
    1 1.3 2 1.3 3 1.3
    LOAD COMB 10 GENERATED INDIAN CODE STEEL_PLASTIC 7
    1 1.3 2 1.3 3 -1.3
    **_AA FLOAD -3 GY
    *_AA1 FLOAD -3 GY
    *_AA2 FLOAD -3 GY
    *_QQ1 FLOAD -3 GY
    *_QQ2 FLOAD -3 GY
    *_QQ3 FLOAD -3 GY
    CODE INDIAN
    CONCRETE TAKE
    END CONCRETE DESIGN
    *PARAMETER 4
    *CODE INDIAN
    *SELECT OPTIMIZED
    PARAMETER 4
    CODE IS800 LSD
    CHECK CODE ALL
    PARAMETER 5
    CODE IS800 LSD
    STEEL MEMBER TAKE OFF LIST ALL
    FINISH
  • The reason for the warning message is - you have specified both member truss and member release command to the same member. You need to remove member truss command from your model. Partial moment release (with 1% fixity) at both end is sufficient to declare a member as truss.
    Also you should rectify the following in your model--
    There are still few floor groups which are not closed. For example, consider group B1 which is closed in three sides. So program is unable to generate floor load on this group.
    You need to change the structure from STAAD PLANE to STAAD SPACE. Your model is not in a plane and there are also out of plane loads assigned on this structure.
  • still some of the member are their in the structure which are going failed.
    now i have used the clauses 3.5 of code 800:2007 for load combination still some thing is going wrong.
    please check my file
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT INCHES NEWTON
    JOINT COORDINATES
    MEMBER INCIDENCES
    FLOOR
    *_A 121
    *_A1 122
    *_A2 131
    *_A3 123
    *_A4 132
    *_A5 124
    *_A6 133
    *_A7 134
    *_A8 126
    *_A9 135
    *_A10 127
    *_A11 136
    *_A12 128
    *_A13 137
    *_A14 129
    *_A15 138
    *_A16 130
    _B1 121 245 568
    _B2 122 246 567 568
    _B3 131 255 566 567
    _B4 123 247 565 566
    _B5 132 256 564 565
    _B6 124 248 563 564
    _B7 133 257 562 563
    _B8 125 249 561 562
    _B9 134 258 517 561
    _B18 130 254 649
    _C2 246 303 569 570
    _C3 255 312 570 571
    _C4 247 304 571 572
    _C5 256 313 572 573
    _C6 248 305 573 574
    _C7 257 314 574 575
    _C8 249 306 575 576
    _C9 258 315 518 576
    _C18 254 311 584
    _D1 302 359 600
    _D2 303 360 599 600
    _D3 312 369 598 599
    _D4 304 361 597 598
    _D5 313 370 596 597
    _D6 305 362 595 596
    _D7 314 371 594 595
    _D8 306 363 593 594
    _D9 315 372 519 593
    _D18 311 368 585
    _Q1 359 416 616
    _Q2 360 417 615 616
    _Q3 369 426 614 615
    _Q4 361 418 613 614
    _Q5 370 427 612 613
    _Q6 362 419 611 612
    _Q7 371 428 610 611
    _Q8 363 420 609 610
    _Q9 372 429 520 609
    _Q18 368 425 601
    *_W1 416
    *_W2 417
    *_W3 426
    *_W4 418
    *_W5 427
    *_W6 419
    *_W7 428
    *_W8 420
    *_W9 429
    *_W10 421
    *_W11 430
    *_W12 422
    *_W13 431
    *_W14 423
    *_W15 432
    *_W16 424
    *_W17 433
    *_W18 425
    _C1 245 302 569
    JOINT
    UNIT METER KN
    ISOTROPIC CONCRETE
    E 2.17185e+007
    POISSON 0.17
    DENSITY 23.5616
    ALPHA 1e-005
    DAMP 0.05
    ISOTROPIC STEEL
    E 2.05e+008
    POISSON 0.3
    DENSITY 76.8195
    ALPHA 1.2e-005
    DAMP 0.03
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL STEEL ALL
    SUPPORTS
    40 TO 44 FIXED
    MEMBER RELEASE
    DEFINE WIND LOAD
    TYPE 1
    *DEFINE WIND LOAD
    *TYPE 1
    SELFWEIGHT Y -1
    FLOOR LOAD
    **_AA FLOAD -4.5 GY
    *_AA1 FLOAD -4.5 GY
    *_AA2 FLOAD -4.5 GY
    *_QQ1 FLOAD -4.5 GY
    *_QQ2 FLOAD -4.5 GY
    *_QQ3 FLOAD -4.5 GY
    FLOOR LOAD
    LOAD COMB 4 COMBINATION LOAD CASE 4
    1 1.0 2 1.0
    LOAD COMB 5 COMBINATION LOAD CASE 5
    1 1.0 2 1.0 3 1.0
    LOAD COMB 6 COMBINATION LOAD CASE 6
    1 1.0 3 1.0
    CODE INDIAN
    CONCRETE TAKE
    END CONCRETE DESIGN
    *PARAMETER 4
    *CODE INDIAN
    *SELECT OPTIMIZED
    PARAMETER 4
    CODE IS800 LSD
    CHECK CODE ALL
    PARAMETER 5
    CODE IS800 LSD
    STEEL MEMBER TAKE OFF ALL
    FINISH
  • The reason for failure is either slenderness or combined interaction. For slenderness check, as you have not specified any parameter (MAIN and TMAIN), program considers the default value. You can change the slenderness limit by specifying MAIN and TMAIN parameter according to Table 3 of IS800:2007 code. You can also bypass the check using MAIN 1 and TMAIN 1 parameter. Else you need to increase the section size or decrease the effective length of the member.
