When attempting to assign connections in RC (version 11.0.0.177), I get a message like this anytime I try to assign a connection:
[Error] No connections could be assigned to joint "Node(214) - Column(417) - Beam(211) - Beam(212) - Brace(443)"[Information] Internal design error in the connection. Please contact technical support
Any ideas as to how I can troubleshoot this issue?
Hola. Yo tengo el mismo problema al asignar una placa base "pinned". Alguna idea de como puedo solucionarlo?
Karl's link above is a good reference. Additionally, see: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/8354/tips-for-using-ram-connection-within-staad-pro-tn
If you have a brace there, be sure to assign a gusset type base plate. The brace needs to be between 20 and 70 degrees and the column a plumb W or HSS shape.
