Seismic Analysis of Boiler Support Structure - Find local structural accelerations
I am performing a seismic analysis of a 15m steel tower structure, which supports a large boiler at a height of around 10m.  I am currently using the IBC code input parameters (SDS, S1 etc.) where STAAD utilises the equivalent force procedure.
The problem I have currently is that the boiler supplier requires to use the acceleration values local to the 6no equipment supports, and I am unable to extract this information from my STAAD model, or even I do not know if STAAD is capable of giving me this information.
I also have the Design Response Spectrum relating the ground accelerations (g) to period (T), however have not included the full spectrum in the analysis input.
Any help would be appreciated.  Thanks.
Parents Reply Children
