Hey!
For a frame structure, the self weight and floor loads (acting along gravity/global Y) which are defined in the dead and live load cases are defined again in the global directions(positive X, Y and Z directions) as dynamic masses for a time history load case. How will the dynamic masses be defined for an elevated water tank?
I have modelled an elevated intze tank where the container is modeled using plates. The loads defined are - selfweight and pressures (hydrostatic and hydrodynamic) which act on the wall and base of the container. These (trapezoidal) pressures act along the local z axis of the plates. So while defining the dynamic masses for the time history load case how should the pressures be defined?
When the tank contains water, and is accelerated during an earthquake, hydrodynamic conditions develop which STAAD cannot handle directly. However, there is an indirect way to simulate such situation when you need to consider the sloshing effect.
Please refer to the attached Technical Note which explains discuss this type of simulation in detail.
can you give me the staad model.
I know this is an old post, but we acquired ADINA since it was made, and it has some powerful capabilities for modeling the interactions of fluids and structures such as this. Here's a wiki: Fully Coupled Fluid Flow Structure Analysis: Sloshing of Oil in a Tank
