PLATE SELECTION VIA OPEN STAAD
Dear All,
I am not able to select Plates using OpenSTAAD.
I have created group "aaaa" for for some plates.
here is code
Sub Main()
Dim objOpenSTAAD As Object
Dim  aaaa As String
Set objOpenSTAAD = GetObject( , "StaadPro.OpenSTAAD")
objOpenSTAAD.View.SelectGroup (aaaa)
End Sub
Please guide.
PN
  • Sekecting Plates.xlsmYou are right. Prima facie, "View.SelectGroup" function does not appear to be working the way it should.  We will check this further. Also, please find below a macro in selecting a group of plates which uses the Geometry.SelectMultiplePlates function. However, the coding is very basic in the sense it expects the plates to be numbered sequentially and that you are not selecting more than 50 plates at a time. I have attached the excel sheet herewith.
    Private Sub CommandButton1_Click()
    Dim start_plate As Long
    Dim end_plate As Long
    Dim no_of_plates As Long
    Dim count As Long
    start_plate = Cells(1, 2).Value
    end_plate = Cells(2, 2).Value
    no_of_plates = 1 + (end_plate - start_plate)
    Dim plateno(50) As Long
    Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
    For count = 1 To no_of_plates
    plateno(count - 1) = start_plate + count - 1
    Next
    objOpenSTAAD.Geometry.SelectMultiplePlates plateno
    Set objOpenSTAAD = Nothing
    End Sub
    Sudip Narayan Choudhury
Reply
    Dim count As Long
    Next
    End Sub
