Hello!
I'm a CE student and im trying to design a structure made up of steel.
I would like to know what connection do I actually use for the support on trusses, and on STAAD.Pro do I place the truss on my structure or do I analyze the structure by two parts first the truss then transfer the loading to the steel columns?
Thank you!
When I thought I was correct this error showed help please
4645.Structure.std
Please go through the following post and modify your model accordingly
http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/21481.error-section-properties-not-entered-for-member
Thank you.
RAJAT
Dear Mr. SYE,
How can I deal with the connection between truss support and the base structure. My roof truss sits on the structure with 15cm gaps(because of truss support height). I am thinking to make the support point of truss and the node of base structure same. On doing so, the bottom member of truss and beam of the base frame becomes same and overlaps. How should I handle this situation ??
Since your truss support is 15 cm high, why don't you model these supports using short vertical members. These would connect your truss and the base frame.
