Faster Way To Model Sloped Roofs?
I know that sloped roofs are generally modeled in RAM SS by adjusting column heights, and I've used this method in the past for simpler roofs. Is there a way in RAM SS to define a plane and extend/cut the columns to that plane? Or a way to achieve something similar?
I'm trying to model a roof that slopes in two directions. As in, if the roof were a rectangle, only one corner would be at the lowest point and the diagonally opposite corner would be at the highest point. (As opposed to the case where one whole edge is at the lowest point and the opposite edge is at the highest point.) This means that every column is at a unique height. The architectural model is not 100% set so there is a chance the roof slope will change multiple times, so I was hoping to avoid going in and changing every column every time something changes.
Thanks!
