I am facing the same problem as some other members in this forum :- ** SECTION IS NOT ADEQUATE WARNING:Reinforcement % exceeds maximum limit.My model is just a residential building-g+1 with basement,and still my columns are failing.Since its G+1,I have not even applied any seismic/wind load.
Kindly help.
Please find my staad file attached.
5047.STaad project 2.std
We follow a strong column weak beam theory and we want to create a structure which is equally strong against both the orthogonal axis. I would suggest column section to be- 250 mm (YD) x 500 mm (ZD). I can see that you applied 7.5 Kn/m UDL to the floor beams and some columns- it should be applied to beams only. Please refer to the modified model.
7801.5047.STaad project 2.std
I am facing the same issue. I increased the column size but I am still getting the same error. Can you please suggest what column size I should assign for my model? I have attached my file.
Design Project 2 (2) (bentley).STD
