I am from the Philippines and our seismic code is patterned after UBC 97. Unlike in STAAD, there is no option in RAM Elements on what code should be the basis for seismic analysis. Below are some concerns I have:
1) Is there an option in RAM E to calculate the design base shear using static procedure (ELF)? This value is needed in calibrating the scale factor for the dynamic analysis.
2) Given that RAM E will calculate ELF base shear, will it also calculate the period of structure using the two methods (Methods A and B) specified in UBC 97?
3) Is there a way to check strong-column weak-beam? How about checking vertical and plan irregularity of the structure?
4) In printing the story drift, I could not verify whether it is based on code or not. As per UBC 97, story drift should be calculated based on maximum inelastic response displacements (Δm) which is 70% the product of R and design level response displacements (Δs). Also, there is no status whether drift is within the limiting value (e.g. 2.5% of story height).
Any help would be greatly appreciated.
Ram Elements does not calculate and ELF seismic loads. It's entirely up to the user how much lateral force to apply and where to apply it.
You can get the natural periods from a dynamic analysis and you can get the total vertical reactions for the dead load case to help.
Any result you get from Ram Elements for deflection from a load case is just the elastic result; unfactored and not limited.
Answer Verified By: Rodolfo Chua Jr.
