Our StaadPro Series 6 Version 20.07.11.50 gives us an Output error as follows which we cannot explain: It did not happen in StaadPro Series 6 Version 20.07.11.33
***STAAD.Pro ERROR . MEMB OR ELEM NO 0 DOES NOT EXIST.
We are looking for a work-around solution if this problem affects our results.
thanks for any help.
I am able to resolve the issue by following this instruction. I had faced the same issue while using IS code with 20.07.11.50. It is resolved when I updated to 20.07.11.90. Thank you for making this help.
