Limcon Bolt Strength
In Limcon Bolt Strength calculation in connections seems giving higher than usual AISC 360-05 procedure. In AISC formulation is 0.75*Fn*Ab. But if you apply same in Limcon results are not consistent. Is there any problem or what is the reason for this.
Parents Reply Children
