Direct Analysis method using AISC 360-10
hi,
I am using Staad pro v8i SS 6, version 20.07.11.70
after analysing piperack staad file, i am getting below note message in output file for every load case and load combination defined using repeat load.
"** NOTE : MOMENT BALANCE DOES NOT CONSIDER SECONDARY EFFECTS OF P-DELTA OR DIRECT ANALYSIS"
Request you to provide the soultion for above problem.
Prash
