<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Best way to model a wire?</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/119255/best-way-to-model-a-wire</link><description>Hi, I&amp;#39;m quite a novice user of the bentley software,
 I was wondering is there a particular method in one of the software packages (ideally staad - as i&amp;#39;m most comfortable with that)) that would be best suited to modelling a wire support system which</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Best way to model a wire?</title><link>https://communities.bentley.com/thread/367774?ContentTypeID=1</link><pubDate>Fri, 13 May 2016 21:42:33 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:63cf2659-4770-44b3-9dd8-8b264cb407b0</guid><dc:creator>Sye</dc:creator><description>&lt;p&gt;Cables can be modeled using beam elements in STAAD.Pro. Following wiki has more information on how to assign cross sectional property to the cables&lt;/p&gt;
&lt;p&gt;&lt;a href="http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/22821.how-to-define-a-cable-section"&gt;communities.bentley.com/.../22821.how-to-define-a-cable-section&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;You should use the Advanced Nonlinear Cable Analysis in STAAD.Pro to analyze the model.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
