Hi all,
I have modeled a Steel Foot Bridge with Lattice Truss structure. I find all the members passing checks (* except few diagonal flats failing in Cl. 6.2.9.1 which is not necessary in this case, to be ignored.)
I will be doing Connection design manually.
My question is Do I still need to do a U-Frame analysis manually ? as is customary in BD or EU codes?
Please check my model which is attached herewith.
Mahesh
Teignmouth.std
I did not see any issues with the model. The only thing that is missing is a LOAD LIST command before both the strength and the serviceability checks just to ensure that strength check is done for the combination 7 and serviceability check is done for load combination 6. Modified file is attached.
I am not too familiar with the standards you mentioned and so cannot comment on whether a U Frame analysis is mandatory or not. However my personal take on this is, a properly substantiated 3D analysis is much more accurate than any manual analysis.
Teignmouth_rev.std
Answer Verified By: Mahesh Gopal
Hi sye,
Thanks a lot. Your advice of using Section wizard has worked for me. I referred your other article to learn Section wizard. I am sorry for bugging you again but there seems to be new issue here now.
I used section wizard to create "double T -back to back". It successfully creates all the properties even Cw (which is HSS). But I noticed it dint give me values of Shear area Ay & Az!!. Should I understand as " this section has no shear area?! which is not possible. OR wizard cant interpret Shear area formulae in this case?
I have uploaded the screenshot of section for your reference and also I couldn't upload the .upt file as this wont allow me.
Thanks again
