Member Take-Off - How to add to Reports
Hi
I have completed my structure and requested Staad to complete a member take off using the "STEEL MEMBER TAKE OFF" command.  This has worked fine and I can see the results in the Staad Output Report (see below).  I now want to compile all my results into the final report including the steel take-off.  When I look through the options in the report setup window I am unable to locate anything regarding the member weight.  Does anyone know if it is possible to add the material take-off to the final report?
Daniel
