Continuous Cable with Intermediate Cable Supports
I am trying to model a continuous cable with 13 intermediate vertical cable supports as well as 2 horizontal supports at the ends. The results don't seem to be making sense, as the supports at the end are only showing the initial tension and no extra horizontal load from the applied vertical load.
there is a similar problem here: communities.bentley.com/.../102697
but it is not exactly the same.
Any guidance would be much appreciated.
Regards, Paul
Parents Reply Children
  • Ok here is how it works. If the Advanced Analysis Plus Engine check box is turned on and you see a green light beside it, you have the license required to perform the Advanced Nonlinear Cable Analysis. You need to change the analysis command from PERFORM ANALYSIS to PERFORM CABLE ANALYSIS. Also you need to add the PERFORM CABLE ANALYSIS and CHANGE command after every load case which is a requirement for performing this type of analysis. Moreover you need to ensure that each load case is a complete load case by itself and contains loads like selfweight of the cable.
    A modified file is attached for your reference.
    Cable Analysis_modified.std
