I have successfully transferred SP3D model to STAAD using CIS/2 transfer.
Now how do I transfer back STAAD model to SP3D?
Thank you.
The transfer of model was successful after contacting Intergraph, thank you for the guidance. But now I am stuck at another place.
1) While I transfer model again from SP3D to STAAD, i.e. while I update model in STAAD using update via CIS/2, the member specifications are changed. E.g. If there is no moment released for the beam or member truss is given to a beam, after updating model, all members are released, irrespective of previous assignments.
2) I am using physical member loads application method to avoid any kind of disturbance to loads while I update the STAAD model via CIS/2. So, for the physical members thus created, is it required to provide DJ1/DJ2 and Lzz design parameter?
