Hello Everyone,
I have modeled a two-storey building in staadpro using three methods and I have gotten varying results. The three scenarios I tried are as followed:
1. I modeled the structure with only the structural frame (ie. beams and columns only), using self weight to account for the frame weight and floor loads to represent my floor loading (inclusive of the slab weight).
2. I modeled the structure with the structural fame along with plates to simulate my slab using self weight to account for the frame and slab weight and floor load to represent my floor loading.
3. I modeled the structure with the structural fame along with plates to simulate my slab similar to method two, however I used the plate stress command so as to ignore the effect of in-plane bending.
I have noticed that the moments generated (based on dead loads only) in my beams has significantly decreased between method one (higher moments/forces) and methods two and three (lower moments/forces). I have also noticed that my storey drift in methods 1 and 3 are fairly similar, while my storey drift using method two is lower. What is the cause of these difference and which method would give my the best representation of my structure (the structural frame of the structure is a rectangle in plane with no horizontal nor vertical irregularities).
thanks
The higher moments in beams for structure 1 is due to the fact that the beams are carrying the whole moment from the applied load whereas when a slab is modeled using plates, it is sharing moments and shears too causing the beam to take less. The story drift for model 1 would be more because the in plane stiffness due to the slab is missing in that model when compared to others.
Regarding which one to use, here is what I think you should do
If the diaphragm is a rigid one, you should use the FLOOR DIAPHRAGM command. That would NOT require modeling the slab with plates but would still give you in-plane rigidity offered by a diaphragm. You can take care of the loads using FLOOR LOAD.
If the diaphragm is flexible, model it using plates. If you DO NOT want the diaphragm to carry any out of plane bending or shear, then only you should specify it as PLANE STRESS but please note in that case you would NOT be able to apply any out of plane loading on it, not even selfweight. Else if the diaphragm can carry out of plane loads, simply model it with plates and it will automatically pick up appropriate moments and shears based on it’s actual stiffness which I think would be more realistic.
I have been using the floor diaphragm for all my design, with or without plates. This however has not changed my story drift values at all, as if I were to remove it my drift values would remain exactly the same as when it is not being used, the only difference is i am able to get the center of rigidity with the diaphragm command activated. I would also like to know if you had any recommendations for semi-rigid diaphragms.
I have included both files in the zip folder (with and without diaphragm).
DIAPHRAGM TEST.zip
