WHY THE RAM CONNECTION WITH IN STAADPRO. SHOW ME THIS PROBLEM?
WHY THE RAM SHOW ME THAT?.. AND HOW I CAN FIX
  • The message indicates that the values for the material properties is not set for Stainless steel. If you are using material Steel and NOT Stainless steel, you can simply ignore the message and proceed. As part of material definition in STAAD.Pro, these values are already included for any material that has been used in the model. For example here is a sample material definition in STAAD.Pro
    For any material for which this has not been included, you can add these properties as part of the STAAD.Pro Material definition as shown below
    For your information, these material properties are listed within the RAM Connection mode at the location below
    Answer Verified By: Jose Gonzalez
Reply
