Hi all,
I am working on assessment of a steel railway bridge. The bridge is made of four plate girders interconnected with cross beams (standard sections). I have decided to use grillage method of analysis. I have following questuions regarding the properties of the elements:
1. Main girders being plate girders, instead of conventional method of calculating properties of plate girder manually and entering it in user table, I decided to create a user table with "wide flange" section type where for additional top plate i used option of "additional composite flange with modular ratio of 1. and for additional bottom plate there was already option in this selection. I have attached snapshot of it for clarity . - Am i doing it right ?
2. cross girders are only connected with steel deck plate, hence Instead of manual property calculations I used wide flange section type in Usertable options. I gave composite additional flange with modular ratio of 1. - Am i doing it right?
both questions are similar upto some extent. i would like to know your expert opinions before I proceed.
I have also attached the model of the bridge. Apparently there seems to be some erroe which I am not able to rectify post analysis.
Error is in User table.: "check area, length and density".
Please help.CHECK-2-7.std
The composite option is only meant for defining sections with steel beam and concrete flanges. I would suggest adding these sections to existing wide flange section database in STAAD.Pro and then use the options to add steel cover plates as needed. Please refer to the picture below
A video on how to add a new section to the existing section database can be downloaded from
http://communities.bentley.com/products/structural/structural_analysis___design/m/structural_analysis_and_design_gallery/258994
Post buckling behavior cannot be simulated using the buckling analysis in STAAD.Pro. Nonlinear Analysis would definitely be a better option to use if you are trying to account for the changes in stiffness due to deformed geometry and stress stiffening effects. However please note that STAAD.Pro Nonlinear analysis accounts for the geometric nonlinear effects ( large displacements) but does not consider material nonlinearity and it cannot account for post buckling stiffness of members.
