I am trying to perform an analysis on an existing two-way concrete slab supported on each side by deep concrete grade beams using STAAD.
Background Info:
As part of a rehab project, a large section of the two-way slab needs to be cut-out and replaced; but the floor needs to remain operational during repairs. As such, steel beams will be placed directly underneath the bottom of the slab around the cut-out and connected to the deep concrete grade beams. In order to make the repairs easier and cheaper, the slab will sit directly on-top of the steel beams without any attachments between the two to resist negative (upward) bending of the slab.
STAAD Model Info:I have modeled the concrete grade beams and the steel beams as well as 1'x1' plate elements (XZ Plane) representing the 12" thick slab. I used the offset command to set the top of the steel beams equal to the top of the concrete beams. Each beam has a node every 1' which sits directly underneath a corresponding plate/slab node. All of the slab/plate element nodes are 6" above the beam nodes in the Global Y direction to represent the center of slab elevation.
Is it possible to connect the concrete slab plate nodes to the steel beam nodes using the Master-Slave Command in the FY direction?
I am concerned about using this command because the slab is only bearing on the steel. I do not want the STAAD analysis to assume a composite connection with studs that would cause the steel beam to bend upwards with the slab in regions of negative moment. I only want the master-slave command to function in the (-)FY direction. Possible?
Would the appropriate master-slave command be RIGID to connect the existing slab which is doweled into the existing grade beams?
Thank you so much for your reply, Sye! Am I correct to assume that it is not appropriate to use the master-slave command to model a slab that is bearing on a steel beam with no attachment between the two?
