Unable to see radial grid lines
Upon creating a radial grid and selecting it on my floor type nothing happened, very confused I tried an orthogonal grid and it shows up fine. The radial and the circular grids I tried creating simply don't appear. My coworker replicated this in about 60 seconds starting a new model, generating a quick ortho and then generating a quick radial and he has the same problem, ortho appears, radial is no where in sight.
Has anyone else experienced this problem or even found a solution?
EDIT: Answer found. Though, you only need 1 radial and 1 circular grid defined to make it appear. Also, I supplied a max distance when I defined the radial grid, that should be able to supersede the necessity of having a circular grid defined. A small workaround is if you make the circular grid distance 0 and name the grid " " [space], but unfortunately the bubble still shows up right in the very middle, but that's a minor eyesore.
