I have several building models with SCBFs as the lateral system. In areas where a column is part of 2 braced frames (in the same plane or perpendicular to each other) the column sometimes fails D1.4a Required Strength checks. The axial load in the column itself does not appear to be too high, but the column capacity is given as 0.00. Any insight on the cause of this or what I can do to resolve this error? An example column and report are shown below for reference. Thanks!
I just ran your file, "SCBF Model with seismic error.rss", using the latest version 15.04. The warnings I get for most of the lower level frame columns are:
This is triggered by having some of the adjacent framing not assigned any frame type. If all members are assign the SBCF frame type those warnings go away. I never get the original error you noted, however. I went back to version 15.03 and the results were the same. Are you able to update your version to the latest?
