How do I model guy wires into my steel pole? Whenever I insert nodes to the steel pole.. The rendering of steel pole is not good.
Also, did my placement of support is correct?
Thank you for who will answer..STAAD INPUT:
STAAD SPACESTART JOB INFORMATIONJOB NAME Bucking Analysis of Steel PoleEND JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES2 0 0 0; 5 0 22.87 0;MEMBER INCIDENCES1 2 5;DEFINE MATERIAL STARTISOTROPIC STEELE 2.05e+008POISSON 0.3DENSITY 76.8195ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY AMERICAN1 PRIS HDC STA 0.625 END 0.175 THI 0.005CONSTANTSMATERIAL STEEL ALLSUPPORTS2 ENFORCED BUT MY5 ENFORCED BUT MX MY MZDEFINE WIND LOADTYPE 1 WIND 1<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 270.000 KMPH 5 2 0 0 0.000 FT 0.000 FT 0.000 FT 1 -1 40.000 FT 25.000 FT 60.000 2.000 0.010 -0 0 0 0 1.044 1.000 1.000 0.850 0 -0 0 0 0.879 1.900 -0.550!> END GENERATED DATA BLOCKINT 4.15589 4.15589 4.26278 4.36047 4.45059 4.53434 4.61266 4.68629 4.75582 - 4.82173 4.88443 4.94425 5.00148 5.05634 5.10906 2.80333 HEIG 0 4.572 - 5.15815 5.74431 6.33046 6.91662 7.50277 8.08892 8.67508 9.26123 - 9.84739 10.4335 11.0197 11.6059 12.192 12.192EXP 1 JOINT 2 5LOAD 1 LOADTYPE Dead TITLE DEAD LOADSELFWEIGHT Y -1 LOAD 2 LOADTYPE Push TITLE SUPER IMPOSEDLOADJOINT LOAD5 FX 35.58 FZ -29.71LOAD 3 LOADTYPE Wind TITLE WINDLOADWIND LOAD X 1 TYPE 1 OPENWIND LOAD Z 1 TYPE 1 OPENLOAD COMB 4 COMBINATION LOAD CASE 41 1.4 LOAD COMB 5 COMBINATION LOAD CASE 51 1.2 2 1.6 LOAD COMB 6 COMBINATION LOAD CASE 61 1.2 3 0.8 LOAD COMB 7 COMBINATION LOAD CASE 71 1.2 3 1.6 2 0.5 PERFORM ANALYSIS PRINT ALLFINISH
You need to insert nodes to add the guy wires. Your property assignments are getting messed up when you are inserting the nodes as each segment is being assigned the same tapered tube property and that is in turn messing up the rendered view. You need to assign the properties of the tapered tube for each segment considering the depth at start and end of the segment.
Regarding support, use FIXED BUT in lieu of ENFORCED BUT unless you want to apply support displacement loading. I don’t think you should release the MY at the base support as that would mean the pole would be able to rotate about it’s axis. I would rather go with a FIXED or a FIXED BUT MX MZ support at the base depending on whether the base can carry moment or not. Also at the top of the structure you have restrained vertical and lateral translations. If you don’t have an actual support at the top retraining these dofs, you should take that support out. I guess the guy wires are going to provide the lateral stability for your pole other than the support at the base.
I hope this helps.
