When I am using the 'Signed Response Spectrum' command, next to the "Mode No." there is a check box with option "Signed". Can someone please explain the use of this checkbox ie when to use it and how it affects my final analysis result?
This option results in the creation of signed values for all results. The sum of squares of positive values from the modes are compared to sum of squares of negative values from the modes. If the negative values are larger, the result is given a negative sign. For example, in any end node of a member, if the shear force is for the first mode is +x1, for second mode is -x2, third mode is + x3, fourth one is -x4 and so on.....then Staad would separate negative term and positive term and then squares of the positive and negative terms are determined separately..like P=( x1^2+x3^2......) and Q=( x^2+x4^2......). Now, the sign corresponds to the larger of P and Q is taken and assigned to the final combined response quantity , in this case the shear force at the said end node. If the P is larger then positive sign would be assigned and if Q is larger then the negative sign would be assigned.
Answer Verified By: Prantik Chatterjee
Please refer to the following section of Technical reference:
5.32.10.1.2 Response Spectrum Specification in Conjunction with the Indian IS: 1893 (Part 1)-2002
You should not use DOMINAT and SIGN option together. SIGN option is not applicable if ABS method of modal combination method is used.
