I am trying to perform a bridge load rating (HS20) using staad pro. Could you give an example to follow?
Thank you
I have attached a std file with moving load generation using a HS20 truck ( modified the Example 12 ). You can find more details on moving load generation as part of Help > Contents > Application Examples > American Examples > and refer to Example 12. The corresponding .std file can also be located within C:\SProV8i SS6\STAAD\Examp\US folder.
6242.EXAMP12_HS20.STD
